Introducing the e-GeForce 7900 GTX
Introducing the
e-GeForce 7900 GTO
Designed for ExtremeHD Gaming. Significantly enhanced performance settings for the 3D enthusiast.
  • Blazing core clocks for ultra-fast graphics performance
  • NVIDIA® SLI™-Ready — Up to 2x the performance of a single GPU for unparalleled gaming experiences
  • 256-bit memory interface and fast GDDR3 memory enables rapid frame rates with all the eye-candy turned on
  • Two integrated dual-link DVI ports support high-definition flat panel displays up to 2560x1600 for an ultra-realistic HD gaming experience
   nVidia e-GeForce 7900 GTX
Limited Lifetime Warranty - 24/7 Customer Support - 90 Days Step-Up™ Program
  • Industry's only GPU architecture with full support for Microsoft® DirectX® 9.0 Shader Model 3.0 — including vertex texture fetch (VTF) — enables advanced shading programs for more realistic effects
Built for Windows Vista™ — the next-generation operating system (OS) from Microsoft®
  • Third-generation GPU architecture built for Windows Vista™
  • Delivers best possible experience when running the Windows Vista™ 3D graphical user interface
  • NVIDIA® PureVideo™ technology delivers high-quality VMR pipeline for best-in-class video for Windows Vista™
Article Viewed: 55410 times since 9/27/2006
