Introducing the e-GeForce 7900 GT KO
Introducing the e-GeForce 7900 GT KO Series
Designed for ExtremeHD Gaming. Significantly enhanced performance settings for the 3D enthusiast.
The 7900 GT KO features EVGA's own high-efficiency thermal solution. The memory is now covered by the innovative EVGA fan, which allows for better cooling (6 degrees Celsius, on average). Gamers will appreciate the higher clock speeds and improved performance made possible by this new and improved cooling solution exclusively from EVGA.
7900 GT KO Superclocked™ | 7900 GTX | 7900 GT | 7600 GT | 7600 GS
nVidia e-GeForce 7900 GT KO
Limited Lifetime Warranty - 24/7 Customer Support - 90 Days Step-Up™ Program
Up close and personal with the 7900 GT KO
e-GeForce 7900 GT KO high-efficiency thermal solution    e-GeForce 7900 GT KO high-efficiency thermal solution
  • Blazing core clocks for ultra-fast graphics performance
  • NVIDIA® SLI™-Ready — Up to 2x the performance of a single GPU for unparalleled gaming experiences
  • 256-bit memory interface and fast GDDR3 memory enables rapid frame rates with all the eye-candy turned on
  • Two integrated dual-link DVI ports support high-definition flat panel displays up to 2560x1600 for an ultra-realistic HD gaming experience
  • Industry's only GPU architecture with full support for Microsoft® DirectX® 9.0 Shader Model 3.0 — including vertex texture fetch (VTF) — enables advanced shading programs for more realistic effects
Built for Windows Vista™ — the next-generation operating system (OS) from Microsoft®
  • Third-generation GPU architecture built for Windows Vista™
  • Delivers best possible experience when running the Windows Vista™ 3D graphical user interface
  • NVIDIA® PureVideo™ technology delivers high-quality VMR pipeline for best-in-class video for Windows Vista™
256-P2-N564-AX
SPECS AT A GLANCE
 Video Card   e-GeForce 7900 GT KO
 Part Number   256-P2-N564-AX
 Core Clock Speed   500MHz
 Pixel Pipelines   24
 Memory Clock Speed   1500MHz
 Memory Bandwidth   48.0GB/sec
 Bus   PCIe
7900 GT KO Benchmarks (3DMark06)
AVAILABLE AT THESE FINE E-TAILERS:
UNITED STATES
Newegg    Monarch
CANADA
Previous Article Next Article
Article Viewed: 33093 times since 4/25/2006
