Introducing the e-GeForce 7900 GTX
Introducing the e-GeForce 7900 GTX Series
7900 GT KO Superclocked™ | 7900 GT KO | 7900 GT | 7600 GT | 7600 GS
Designed for ExtremeHD Gaming. Significantly enhanced performance settings for the 3D enthusiast.
EVGA will offer three different levels with different cooling solutions or services:
  1. Signature Series - With EVGA's proprietary thermal solution and cherry-picked speed and service.
  2. KO Series - With EVGA's own high-efficiency thermal solution.
  3. CO Series - With a copper thermal solution.
   nVidia e-GeForce 7900 GTX
  • Blazing core clocks for ultra-fast graphics performance
  • NVIDIA® SLI™-Ready — Up to 2x the performance of a single GPU for unparalleled gaming experiences
  • 256-bit memory interface and fast GDDR3 memory enables rapid frame rates with all the eye-candy turned on
  • Two integrated dual-link DVI ports support high-definition flat panel displays up to 2560x1600 for an ultra-realistic HD gaming experience
  • Industry's only GPU architecture with full support for Microsoft® DirectX® 9.0 Shader Model 3.0 — including vertex texture fetch (VTF) — enables advanced shading programs for more realistic effects
Built for Windows Vista™ — the next-generation operating system (OS) from Microsoft®
  • Third-generation GPU architecture built for Windows Vista™
  • Delivers best possible experience when running the Windows Vista™ 3D graphical user interface
  • NVIDIA® PureVideo™ technology delivers high-quality VMR pipeline for best-in-class video for Windows Vista™
512-P2-N575-AX
SPECS AT A GLANCE
 Video Card   e-GeForce 7900 GTX SUPERCLOCKED
 Part Number   512-P2-N575-AX
 Core Clock Speed   690MHz
 Pixel Pipelines   24
 Memory Clock Speed   1760MHz
 Memory Bandwidth   56.32GB/sec
 Bus   PCIe
512-P2-N570-AX
SPECS AT A GLANCE
 Part Number   512-P2-N570-AX
 Core Clock Speed   650MHz
 Pixel Pipelines   24
 Memory Clock Speed   1600MHz
 Memory Bandwidth   51.2GB/sec
 Bus   PCIe
Previous Article Next Article
Article Viewed: 67513 times since 3/9/2006
