Infinite Looping Issue
There is some
talk going around regarding the notorious "Infinite Loop" or
NV Loop/BSOD error that have been plaguing many people using later versions
of the Detonator XP drivers. Apparently,
the problem can occur with different results when running games or applications
that utilize the OpenGL or Direct3D API's.
Common error symptoms that have become evident in OpenGL or Direct3D include
spontaneous reboots, hardware lockups, insufficient virtual memory error
(Windows XP) or Blue Screen of Death (BSOD) describing an "infinite
loop" error with an NVIDIA driver, more notably with the nv4_disp.dll
file. A
sample error message reads as follows:
"Stop 0x000000EA or THREAD_STUCK_IN_DEVICE_DRIVER -
A device driver problem is causing the system to pause indefinitely. Typically,
this problem is caused by a display driver waiting for the video hardware
to enter an idle state. This might indicate a hardware problem with the
video adapter or a faulty video driver."
This problem has been reported to occur when using the Detonator XP drivers
version 23.11 in Windows XP and in some cases, Windows 2000. Therefore,
revert to using an earlier version of the driver, anywhere from 12.41
and above with the 21.83 driver version being preferred. There is no definite
answer as to whether or not this issue is more of a hardware vendor or
software related issue, but a safe bet to say that it is a combination
of both. It
turns out that the video drivers were allocating too many system resources,
more notably RAM to the video card, putting too much load on the memory
timing procedure. This problem seems to occur more frequently with a certain
driver set, version 23.11, more so in a few motherboard chipsets ranging
anywhere from Intel to VIA.
Both motherboard chipset manufactures, Microsoft and NVIDIA are currently
working together to alleviate the problem. Please check with chipset manufactures
regarding any new patches or updates made for your particular motherboard
model. One of these chipset manufactures, VIA, has come out with a BETA
version of the patch that has reportedly corrected the issue for some
and is available here.
VIA's latest revision of their "4in1" chipset driver suite,
version 4.37, includes the new patch and is readily available on their
driver download page.
If the problem persists, the problem may lie with lower quality motherboard
memory or aggressive memory settings found in the motherboard BIOS that
must be set to factory defaults or lower. Please check with your motherboard
manufacture for preferred BIOS settings.The following are BIOS memory
settings for the VIA chipset:
DDR266 motherboards
(Recommended settings):
SDRAM
Cycle Lenth:
Cas
setting of 2.5
Bank
Interleave:
Enable
or Disable (only if 1 DIMM is installed)
Precharge
to Active (Trp):
3T
to Precharge (Tras):
6T
to CMD (Tras):
2T
DRAM
Burst Length:
4
DRAM
Drive Length:
Auto
CPU
to DRAM:
Slow
or medium
PC133
motherboards (Recommended settings):
DRAM
Timing by SPD:
Disabled
DRAM
Clock:
HCLK
at 100FSB if 133FSB fails
SDRAM
Cycle Length:
3
Bank
Interleave:
Enable
DRAM
Drive Strength:
Auto
Hole:
Disabled
or Enable at 15M-16M
Motherboard
settings information comes courtesy of www.VIAarena.com
