EVGA 9800GX2 Superclocked, KO and SSC
The EVGA 9800 GX2 Superclocked, KO and SSC
Introducing the EVGA 9800GX2 Superclocked, KO and SSC
EVGA is now introducing an update to the fastest graphics solution, the EVGA 9800GX2 Superclocked, KO and SSC. Up to 86.4 Billion/sec Texture Fill Rate on the SSC Model gives you the ultimate in extreme performance. 100% testing ensures the highest level of performance and stability possible. This same level of testing and quality allowed Vince k|ngp|n Lucido to hit nearly 30,000 points with a single EVGA 9800GX2. EVGA makes the GX2 even more extreme giving you the ultimate in high-definition gaming performance.
Extreme Performance:
  • 2x 65nm GPUs @ 675MHz
  • 256 Stream Processors at 1674MHz
  • 86.4 Billion/sec Texture Fill Rate
  • 134.4GB/s Memory Bandwidth
Features:
  • Full DX10 support Full Direct X 10 and Shader Model 4.0 support delivers uparalleled levels of graphics realism and film-quality effects.
  • Unified Shader Architecture - Combines vertex, pixel and geometry shaders for an overall more efficient architecture.
  • Second Generation Purevideo HD High-definition video decoder and post-processor delivers unprecented picture clairty, smooth video and accurate color for movies and video.
  • Quad SLI Technology Industry leading Quad SLI technology offers amazing performance scaling by implementing 4-way AFR, for the worlds fastest gaming solution in Windows Vista.
  • 128-bit HDR with FSAA Realistic High Dynamic Range lighting, now with support for anti-aliasing!
  • HDMI Output An integrated HDMI connector allows you to send both high-definition video and audio signals to your HDTV via a single cable.
PureVideo HD technology
  • An integrated HDMI connector allows the sending of both high-definition video and audio signals via a single cable.
  • Dynamic contrast enhancement and color stretch video processing.
  • Hardware acceleration of high definition movies and dual-stream picture-picture content.
EVGA 790i + 9800GX2 + KINGPIN = 3DMark06 World Record
All these new technologies found in the e-GeForce 9 series GPU processors allow the PC Platforms to experience high-resolution, high performance gaming, and stellar high-definition visuals.
9800GX2 Powersupply Notice
Article Viewed: 106239 times since 4/1/2008 7:08:12 AM
