ESA
The Ultimate GPU Motherboard
ESA monitoring delivers system control in real-time.
ESA stands for Enthusiast System Architecture. ESA is an open industry standard that enables PC components to communicate status and control in real-time. ESA monitoring and control will extend to processors, motherboards, video cards, cooling hardware, and power supplies.
ESA enables unprecedented control over PCs to achieve better performance, thermal, and acoustic management. The nForce 780i SLI motherboard is EVGAs first ESA certified motherboard; allowing fine tuning on the fly when coupled with ESA certified components. The new NVIDIA Control Panel will be the interface to provide access to monitor and tune your ESA certified system components.
On the fly control!
Key Features:
  • Monitor temperatures and fan speeds
  • Adjust voltages, and fan speeds
  • Monitor embedded thermal sensors
  • Display voltages and bus speeds
Now you can own the EVGA 780i SLI Motherboard which takes full advantage of ESA technology.
132-CK-NF79-A1
nForce 790i Ultra SLI
Part Number 132-CK-NF79-A1
CPU Support Intel Socket 775
Chipset NVIDIA nForce 790i Ultra SLI Chipset
Memory Support DDR3 1066/1333/1600/2000 MHz
FSB Speed Supports 800/1066/1333/1600 Mhz
SATA Header 7
SATA Type 300MB/sec
USB Ports 10
PCIE Slot 3 x PCIe x16, 2 x PCIe x1, 2 x PCI
upon registration
132-CK-NF78-A1
nForce 780i SLI
Part Number 132-CK-NF78-A1
Chipset NVIDIA nForce 780i SLI Chipset
Memory Support DDR2 533/667/800/1200MHz SLI-Ready memory
FSB Speed Supports 533/800/1066/1333 Mhz
SATA Header 6
SATA Type 300MB/sec
USB Ports 10
PCIE Slot 3 x PCIe x16, 1 x PCIe x1, 2 x PCI
upon registration
122-CK-NF68-A1
nForce 680i SLI
Part Number 122-CK-NF68-A1
Chipset NVIDIA nForce 680i SLI Chipset
FSB Speed Supports 1066/1333 Mhz
SATA Header 6
SATA Type 300MB/sec
USB Ports 10
PCIE Slot 2 x PCIe x16, 1 x PCIe Graphics expansion slot, 2 x PCIe x1, 2 x PCI
upon registration
Article Viewed: 79775 times since 12/17/2007 7:34:22 AM
