Crank up the graphics horsepower - NVIDIA® GeForce® 7950 GT
NVIDIA® SLI™-Ready GeForce® 7950 GT graphics processing units (GPUs) crank up the graphics horsepower with a whopping 512MB and a 550 MHz core. Power through games with exceptionally smooth frame rates at widescreen resolutions up to 2560x1600, and enjoy ultra fluid, high-definition video playback using advanced NVIDIA® PureVideo™ HD technology. More is better.
Designed for extreme HD gaming
  • 90nm process delivers blazing core clocks for ultra-fast graphics performance
  • NVIDIA® SLI™-Ready Up to 2x the performance of a single GPU for unparalleled gaming experiences
  • 256-bit memory interface and fast GDDR3 memory enables rapid frame rates with all the eye-candy turned on
  • Two integrated dual-link DVI ports support high-definition flat panel displays up to 2560x1600 for an ultra-realistic HD gaming experience
   NVIDIA GeForce 7950 GT
As you read about HD DVD and Blu-ray movie playback on PCs, you'll come across many acronyms describing new technologies and standards. We've provided a glossary of some of the most common terms. Click here to learn more about HDCP.
Limited Lifetime Warranty - 24/7 Customer Support - 90 Days Step-Up™ Program
Built for Windows Vista™ the next-generation operating system (OS) from Microsoft®
  • Third-generation GPU architecture built for Windows Vista
  • Delivers best possible experience when running the Windows Vista 3D graphical user interface
  • NVIDIA® PureVideo™ technology delivers high-quality VMR pipeline for best-in-class video for Windows Vista
512-P2-N635-AR
SPECS AT A GLANCE
 Video Card   e-GeForce 7950GT KO 512MB
 Part Number   512-P2-N635-AR
 Core Clock Speed   560MHz
 Pixel Pipelines   24
 Memory Clock Speed   1450MHz
 Memory Bandwidth   46.4GB/sec
 Bus   PCIe
512-P2-N633-AR
SPECS AT A GLANCE
 Video Card   e-GeForce 7950 GT 512MB EVGA Fan
 Part Number   512-P2-N633-AR
 Core Clock Speed   550MHz
 Pixel Pipelines   24
 Memory Clock Speed   1400MHz
 Memory Bandwidth   44.8GB/sec
 Bus   PCIe
  • Industry's only GPU architecture with full support for Microsoft® DirectX® 9.0 Shader Model 3.0 including vertex texture fetch (VTF) enables advanced shading programs for more realistic effects
  • 64-bit floating point texture filtering and blending delivers true high dynamic-range (HDR) support for cinematic lighting effects
  • Adaptive transparency antialiasing algorithm provides dramatically improved image quality with minimal performance overhead
  • Dedicated on-chip video processors dramatically increase video processing performance
    • H.264, MPEG2, and WMV9 decode acceleration provides unmatched HD and SD video playback and post processing
    • Dedicated video processor frees GPUs shaders to run 3D applications simultaneously
  • Industrys most advanced video algorithms deliver smooth video playback and crisp picture quality
    • Inverse telecine (3:2 and 2:2 pull-down correction) detects and eliminates artifacts introduced during the film to video conversion process
    • Advanced spatial-temporal de-interlacing for high definition and standard definition content provides crisp images on progressive displays
    • High-quality video scaling allows you to change window size to full screen without video noise or artifacts
  • VMR and Overlay video architecture is built for Microsoft® Windows Vista™, Windows® XP and Windows® XP Media Center Edition
Article Viewed: 62810 times since 9/6/2006
