Introducing the e-GeForce 7950 GX2 Series
Two GPUs.
One board.
The e-GeForce 7950 GX2 features a knockout pair of GeForce processors on one irresistibly powerful board. Resetting the bar for single board graphics performance with amazing 3D horsepower and speed, the GeForce 7950 GX2 enables a lightning-fast, hyper-realistic gaming experience with ultra-smooth frame rates. This dual-GPU board features an astounding 1 GB of fast GDDR3 memory and support for resolutions up to 2560 X 1600.
Designed for extreme HD gaming, the 7950 GX2 combines the power of two GeForce 7950 graphics processing units (GPUs) on a single graphics card. This unbelievable graphics horsepower, along with a 512-bit memory interface and an astounding 1GB of fast GDDR3 memory, enable an incredibly smooth, ultra-realistic gaming experience.
nVidia e-GeForce 7950 GX2
Limited Lifetime Warranty - 24/7 Customer Support - 90 Days Step-Up™ Program
NVIDIA GeForce 7950 GX2
Motherboard Compatibility
The following motherboard has been tested and passed
NVIDIA's compatibility testing requirements with
the GeForce 7950 GX2 graphics card:
EVGA nForce 4 SLI x16 Mainboard
Part Number: 123-K8-NF47-AX
Highest Performing Single Graphics Board
Far exceeding the performance of any PC graphics board available today, EVGA's new e-GeForce 7950 GX2 graphics card includes two top-of-the-line, 90nm GeForce 7950 GPUs, delivering 48 pixel pipes and 1GB of graphics memory on a single graphics board.
Architectural efficiency is a major advantage of the e-GeForce 7950 GX2 versus the competition. Each 7950 GPU is only 196 square millimeters in size, allowing efficient power and thermal management of a dual-GPU board consuming a maximum of 143 watts.
An e-GeForce 7950 GX2 board fits into a single PCI Express slot, occupying a two-slot volume. Both 7950 GPUs on a single e-GeForce 7950 GX2 board work in tandem to accelerate the performance of over 250 popular 3D titles. For the few games that may not work well with two GPUs, the 7950 GX2 will operate in single GPU-mode.
Compared to a single 7900 GX2 dual-GPU board used in initial Quad SLI systems, the e-GeForce 7950 GX2 delivers similar performance, but is only nine inches long to better fit most cases and permit more flexible peripheral installation and cooling solutions. A 7950 GX2 card will work in both SLI and non-SLI motherboards.
  • Advanced visual effects engines deliver ultra-realistic gaming experiences and unparalleled image quality
  • NVIDIA® PureVideo™ technology delivers high-definition home-theater quality video to the PC
  • Built for Windows Vista™ — the next-generation operating system (OS) from Microsoft®
Up close and personal with the e-GeForce 7950 GX2
e-GeForce 7950 GX2    e-GeForce 7950 GX2
01G-P2-N592-AX
SPECS AT A GLANCE
 Video Card   e-GeForce 7950GX2 1GB
 Part Number   01G-P2-N592-AX
 Core Clock Speed   500MHz
 Pixel Pipelines   48
 Memory Clock Speed   1200MHz
 Memory Bandwidth   76.8GB/sec
 Bus   PCIe
Note: QUAD SLI support obtained by combining two e-GeForce 7950 GX2 boards will be provided through a future NVIDIA ForceWare driver release, and will only be available initially through authorized system builders.
Features & Benefits:
  • Full Microsoft® DirectX® 9.0 Shader Model 3.0 Support
  • Built for Microsoft® Windows Vista™
  • NVIDIA® SLI™ Technology
    Important Note: SLI support for the e-GeForce 7950 GX2 will be provided through a future NVIDIA ForceWare driver release, and will only be available initially through authorized system builders.
  • NVIDIA® CineFX™ 4.0 Engine
  • Full-Speed 128-Bit Studio-Precision Computation
  • Transparency Antialiasing
  • NVIDIA® Intellisample™ 4.0 Technology
  • True High Dynamic-Range (HDR) Rendering Support
  • HDCP Support*
    *Requires other compatible components that are also HDCP capable such as a HDCP capable display and HDCP capable media player.
  • 90nm Process Technology
  • High-Speed 512-Bit wide GDDR3 Memory Interface
  • NVIDIA® PureVideo™ Technology
  • NVIDIA PureVideo Features:
    • Adaptable Programmable Video Processor
    • MPEG-2 Decode Acceleration
    • H.264 Decode Acceleration
    • WMV Decode Acceleration
    • Inverse Telecine (3:2 & 2:2 Pulldown Correction)
    • Bad Edit Correction
    • Spatial-Temporal De-Interlacing
    • High-Quality Scaling
    • Video Color Correction
    • Integrated SD and HD TV Output
    • UltraShadow II Technology
    • Full-Speed 32-Bit Color Precision
    • Normal Map Compression
    • Dual Dual-link DVI Support
    • Dual 400MHz RAMDACs - Blazing-fast RAMDACs support dual QXGA
AVAILABLE FROM THIS FINE EVGA ETAIL PARTNER:
UNITED STATES
Newegg
Article Viewed: 103699 times since 6/5/2006
