256-BIT
ADVANCED MEMORY INTERFACE
Wider memory data path with next generation controller technology
for superior performance throughput.
NVIDIA
CINEFX 2.0 ENGINE
Advanced pixel shaders deliver 2x the floating-point shader
pixel performance of previous generations
Support for Microsoft® DirectX® 9.0 (DX9) pixel shader
2.0+
Support for DX9 vertex shader 2.0+
Long pixel programs up to 1,024 instructions
Long vertex programs up to 256 static instructions with up
to 65,536 instructions executed
Dynamic, conditional execution and flow control
Architected for Cg and Microsoft HLSL for maximum compatability
for next-generation content
128-bit, studio-quality, floating-point precision computation
through the entire rendering pipeline
Native hardware support for 32 bpp, 64 bpp, and 128 bpp rendering
modes
Up to 12 pixel shader operations per clock
Up to 16 texture shader operations per clock
Support for sRGB texture format for gamma textures
DirectX and S3TC texture compression
Optimized for 32-, 24-, 16-, 15-, and 8-bpp modes
True-color, 64x64 hardware cursor alpha
Multibuffering (double, triple or quad) for smooth animation
and video playback.
INTELLISAMPLE
HCT TECHNOLOGY
Increased visual quality at higher resolutions through advances
in compression, anistropic filtering, and antialiasing technology
Blistering-fast antialiasing and compression performance
Support for advanced lossless compression algorithms for both
color, texture, and z data at even higher resoltuions and
frame rates
Fast x-clear |
ULTRASHADOW
TECHNOLOGY •
Accelerates shadow volumes for next-generation games
Accurately maintains shadows while discarding non-useful information
ADVANCED DISPLAY PIPELINE •
Integrated NTSC/PAL TV encoder supporting resolutions up to
1024x768 without the need for panning with built-in Macrovision
copy protection
DVD and HDTV-ready MPEG-2 decoding up to 1920x1080i resoltions
Dual, integrated 400 MHz RAMDACs for display resolutions up
to and including 2048x1536@85 Hz
Dual DVO ports for interfacing to txternal TMDS transmitters
Internal TV support
VIP 1.1 interface support for Video In function
Microsoft Video Mixing Renderer (VMR) support for multiple
video windows with full video quality and features in each
window
NVIDIA
DIGITAL VIBRANCE CONTROL 3.0
DVC image sharpening controls
DVC color controls
ADVANCED
TECHNOLOGY
AGP 8X including Fast-Writes and sideband addressing
0.13-micron precess technology for higher levels of integration
and higher operating clock speeds
Advanced thermal management and thermal monitoring
40 mm x 40 mm, BGA 1309 flip-chip package
OPERATING
SYSTEM SUPPORT
Microsoft Windows® XP
Windows ME
Windows 2000
Windows 9x
API
SUPPORT
Comprehensive Microsoft DirectX 9.0 (and lower) support
OpenGL 1.4 (and lower) support
