EVGA’s Record-Breaking and Award-Winning X299 Motherboards Just Got an Upgrade
EVGA X299 Motherboards are Optimized For The New Intel® Core™ X-Series Processors
EVGA X299 motherboards immediately set the bar for performance, cooling and stability. Since then, EVGA has improved the cooling, reinvented the modern motherboard BIOS, and continued to shock the enthusiast world with the EVGA X299 DARK. And these boards are only just getting started….
With the release of the New Intel® Core™ X-Series Processors, EVGA X299 Motherboards are ready and waiting for them. Current owners need only update the motherboard BIOS for full compatibility; new owners can boot into the motherboard BIOS and update the BIOS with their brand-new CPUs.
have the features you need to best support the New Intel® Core™ X-Series Processors
EVGA X299 motherboards were engineered to excel with Intel®’s most powerful Core™ X-Series processors, including the new Intel® Core™ i9-10980XE.
EVGA X299 Motherboards Support 32GB DIMMs
EVGA X299 motherboards were designed to support
every type of user and situation, including content creators, gamers, and enthusiasts. With 32GB DIMMs, the possibilities are endless.
With Great Power comes...
... A Need for Great Cooling
Whereas some competitors received a bit of heat by reviewers, EVGA won widespread acclaim for its X299 DARK VRM cooling solution. All EVGA X299 motherboards feature a thicker heatsink and/or active cooling on the VRM heatsink, leading to higher overclocks and stability under load.
EVGA X299 Motherboards have the best BIOS support for the New Intel® Core™ X-Series Processors
More recently, EVGA provided a new BIOS update that revolutionized overclocking with OC Robot and in-BIOS stress testing. In an industry first, EVGA X299 motherboard owners could change settings and stress test them without ever leaving the BIOS.
Now, with the latest X299 motherboard BIOS updates, owners can use OC Robot to configure PerCore voltage settings, and stress test those settings, including AVX2 loads, without the need for an OS or third-party utility.*
Step 3 – Once complete, apply the settings, accept the changes and reboot
Step 4 – Boot into the BIOS and view your new settings.
Step 5 – Double-check your settings by running a stress test. If the temperatures are too high or the system feels unstable, don’t worry! Just close the stress test, change your settings, and run the test again. Your new settings and voltages will be tested without the need to save and restart the system.
Step 6 – Stress test your CPU one more time and enjoy your new, stable overclock!
BRAND NEW - OC ROBOT
Step 1 – Go into your X299 BIOS and select EVGA OC Robot
Step 2 – Select your OC Robot Type and run the EVGA OC Robot
*OC Robot does not support Kaby Lake-X processors
World Records and Awards
to prove they deserve the
EVGA X299 Motherboards have been proven time and time again to be the best choice for enthusiast-grade performance, stability, and gaming by many PC hardware reviewers. Led by the EVGA X299 DARK, which smashed 12 Overclocking World Records before it even debuted, EVGA X299 motherboards lead by example.
Make an EVGA X299 Motherboard Your Choice to harness the power of the latest and greatest New Intel® Core™ X-Series Processors
EVGA X299 DARK
- 100% Solid State Capacitors
- 13 Temperature and 24 Voltage Sensors
- 1x M.2 Key E (32mm) + 2x M.2 Key M (80mm,110mm)
- 300% more gold content in the CPU socket
- 4-Way SLI® Support
- Advanced VRM Fansink with Heatpipe
- CLEAR CMOS, Power and Reset
- Creative Sound Core3D Audio with Output Amplifiers
- Dual 8 Pin CPU Power
- EVGA Probe-It Connector
- External Clock Gen.
- Full Body Cover with Active PCH and M.2 Cooling
- Highly-Efficient 16 Phase Power Design
- Intel VROC Support
- Onboard Power, Reset, and Clear CMOS
- Onboard Temperature and Voltage Monitoring
- Right-angle power, FAN, USB 3.0 headers
- Triple BIOS Support
- Windows 10 64bit Support
EVGA X299 MICRO ATX 2
- Supports Intel Core X-series Cascade Lake-X and Skylake-X Processors
- Intel® Optane™ Memory Ready
- EVGA's Latest GUI BIOS Featuring OC Robot and In-BIOS Stress Testing
- Highly-Efficient 14 Phase Digital VRM
- 1x M.2 Key E (32mm) + 1x M.2 Key M (80mm)
- Reinforced PCIe and DIMM slots
- SPI flashing via USB allows you to flash your BIOS without a CPU
- New Integrated EVGA WiFi/BT Module
- Included Intel Dual-band WiFi / BT4.2 with external antenna
- Onboard CPU Temp Monitor
EVGA X299 MICRO ATX
- Highly Efficient 12 Phase Digital VRM
