green is the new gold
The EVGA SuperNOVA G5 joins the elite ranks of the EVGA 80 PLUS Gold power supplies. As the successor to the award-winning G3 series, the G5 power supplies continue to push the envelope with the latest certifications and Intel power-on standards. Starting with 80 PLUS Gold certification, fully-modular cable design, 100% Japanese capacitors, and an ultra-quiet 135mm Fluid Dynamic bearing fan with EVGA ECO mode, these power supplies are built for performance and silence.
gold rated
efficiency
80 PLUS Certification ensures your power supply isn't wasting power and turning it into excess heat. Under typical load, this power supply is 91% efficient or higher.
active clamp design
low ripple and noise
The G5 power supplies also feature an active clamp circuit design, DC-to-DC converter, and active PFC to provide tight voltage regulation and low ripple and noise.
fully modular
design
Use only the cables you need, reducing cable clutter and improving case airflow.
100%
Japanese Capacitors
Get the most reliability and greatest performance with the use of the highest possible quality Japanese Capacitors.
100%
Aluminum Solid State Capacitors on the modular board
Solid State Capacitors improve efficiency and reduce the impact of environmental factors after power is converted to DC, but before it leaves the power supply.
ultra quiet 135mm fluid dynamic bearing fan with
EVGA eco mode
The G5 features a larger fan than the G3 to reduce noise without increasing the size of the power supply.
made to
Protect & serve
The EVGA G5 Series also includes a full suite of protections (OCP, OVP, UVP, OPP, SCP, OTP) for safety and security, and are covered by EVGA's industry-leading 10 Year Warranty and Customer Support.
Features
- 80 PLUS Gold certified, with 91% (115VAC) / 92% (220VAC~240VAC) efficiency or higher under typical loads
- Fluid Dynamic Bearing Fan for ultra-quiet operation and increased lifespan.
- Active Clamp +DC to DC design for efficient operation
Specs
- OPP (Over Power Protection)
AC Input | 100 - 240 VAC, 15-8A, 50/60 Hz | ||||
999.6W | |||||
Output Power | 1000W @ +50C |
Features
Specs
AC Input | 100 - 240 VAC, 12-5A, 50/60 Hz | ||||
MAX Output | 24A | 24A | 70.8A | 0.5A | 3A |
849.2W | |||||
Combined | 120W | 849.2W | 6W | 15W | |
Output Power | 850W @ +50C |
Features
Specs
AC Input | 100 - 240 VAC, 10-5A, 50/60 Hz | ||||
MAX Output | 24A | 24A | 62.5A | 0.5A | 3A |
750W | |||||
Combined | 120W | 750W | 6W | 15W | |
Output Power | 750W @ +50C |
Features
Specs
MAX Output | 24A | 24A | 54.1A | 0.5A | 3A |
649.2W | |||||
Combined | 120W | 649.2W | 6W | 15W | |
Output Power | 650W @ +50C |
