Solid Gold
Foundation
The EVGA GD Series of power supplies builds upon a Solid Gold Foundation. Available in 700W, 600W and 500W, these power supplies are engineered with the same level of performance at a great value. Featuring 80 Plus Gold certified efficiency and a reliable Japanese main capacitor, the EVGA GD Series is a great choice for those looking for a great quality power supply at a great price.
Standard Form Factor
Will fit most mATX, ATX, E-ATX, HPTX, and XL-ATX cases.
All black sleeved cable
Get that high-end look while staying within your budget.
Game-Ready Performance
The GD power supplies prove that high-performance gaming doesn't belong to only high-priced power supplies. See the accompanying chart to find out which GD power supply is the right choice for your next EVGA GeForce RTX™ or GeForce® GTX gaming card.
100-GD-0700 | 100-GD-0600 | 100-GD-0500 |
RTX 2080 Ti | RTX 2070 | RTX 2060 |
RTX 2080 | RTX 2060 | GTX 1660 Ti |
RTX 2070 (2-Way SLI) | GTX 1660 Ti | GTX 1660 |
RTX 2070 | GTX 1660 | GTX 1650 |
RTX 2060 | GTX 1650 | |
GTX 1660 Ti | ||
GTX 1660 | ||
GTX 1650 |
Features
Gold rated efficiency
Reliable Japanese Main Capacitor
Get the most reliability and performance with the use of a high-quality Japanese main capacitor.
To protect and to serve
This PSU will cover your circuits with complete protection: OCP, OVP, OTP, OPP, and SCP.
DC to DC Converter
Voltage step-down for rock-solid power, stability, and minimal signal noise (for 3.3V and 5V).
World leading
