The X299 MICRO ATX 2 is a reimagined mATX board designed to support the power, performance, and cooling necessary to power Intel's most powerful i9 CPU for the X299 Chipset. With a 14 Phase power design, a thick VRM heatsink/fan, two 8 pin EPS power connectors, an additional 6 pin PCIe power connector, and external BCLK, this motherboard was born for the enthusiast desiring maximum power in a small form factor. The X299 MICRO ATX 2 supports current storage standards, including M.2 NVMe, Intel Optane, Intel VROC and SATA 6Gb/s to give you a blazing fast access to your data, while Intel Dual-Band WIFI/BT and an Intel i219V Gigabit NIC Keeps you connected. If you need a small motherboard capable of pure performance, the X299 MICRO ATX 2 strikes the perfect balance for features and power.
EVGA NEW GUI BIOS*
Witness the power of EVGA's new fully armed and operational GUI BIOS! Upon booting your EVGA X299 MICRO ATX 2, select a conservative preset overclock using the Gamer Mode, or use the EVGA OC Robot to overclock your system automatically. Prefer to overclock yourself? EVGA's latest GUI BIOS allows you to set your own overclock settings and stress test those settings without leaving your BIOS! EVGA's newest GUI BIOS is now the gold standard for overclocking.
*The new GUI BIOS for X299 MICRO ATX 2 will be available at launch on the EVGA Download Center.
HIGHLY-EFFICIENT 14 PHASE DIGITAL VRM WITH ACTIVE COOLING
The X299 MICRO ATX 2 features a 14 phase digital VRM design capable of running and overclocking the most powerful Intel® Core™ X-series i9 processors available. More power requires…more power. An additional 8pin CPU power connector allows for higher overclocks and more stability. Even more power requires more cooling. A specially-designed VRM heatsink/fan keeps the VRM cool even while you're pushing your CPU to the limit.
NEW EVGA INTEGRATED WIFI AND BLUETOOTH MODULE
An elegant board deserves an elegant wireless solution. The new EVGA integrated WiFi module contains the Intel® AC8265 WiFi/BT and eliminates the need for wires. Just add the included wireless antennas, and you're good to go. Prefer a wired connection? The Intel® i219V Gigabit NIC can handle all your streaming, sharing, and gaming needs.
INTEL® OPTANE™
MEMORY READY*
Accelerate your PC with Intel®'s latest solutions for blistering fast boot times and increased performance for gaming and everyday tasks.
*Intel® Optane™ Support via optional PCIe adapter (Not Included).
METAL REINFORCED PCIe AND DIMM SLOTS
Feel confident in the strength of your motherboard slots when using heavy graphics cards or memory DIMMs.
M.2 KEY-M 80MM SLOT
M.2 Key-M SSDs are currently the most popular storage medium available. The 80mm slot supports PCIe and NVMe-based Solid State drives.
ONBOARD POWER, RESET AND CMOS BUTTONS WITH POST CODE/TEMPERATURE LED
A staple of EVGA motherboards, the power, reset, and CMOS reset buttons are built into the motherboard, so you don't need to worry about wiring the board to a case when testing or benching in an open air environment.
EVGA E-LEET X
Monitor your system's vitals, overclock, and more in your OS with EVGA E-LEET X!
HIGH GOLD CONTENT FOR CPU SOCKET
A higher volume of precious metal (150% Gold) use in the socket greatly improves the conductivity and produces a cleaner signal due to less resistance / impedance.
FLASH THE BIOS WITHOUT A CPU!
The X299 MICRO ATX 2 is EVGA's first motherboard that does not require a CPU to flash your BIOS. Simply connect a power supply, connect the provided USB, and hold the reset button for several seconds to start the process. Compatibility issues are now a thing of the past.
Specifications
- Chipset: Intel X299
- Socket: Intel Socket 2066, Supports Intel Socket 2066
- Form Factor: mATX
- SLI: 2-Way
- Memory: Up to 4 DIMM Quad-Channel (up to 128GB) DDR4 4000MHz+
- USB: 8 USB 3.1 Gen.1 / 4 USB 2.0
- USB 3.1 (Rear I/O): 2 Type-A
- USB 3.1 (Internal Header): 0
- SATA: 6 SATA 6.0Gb/s Ports
- Ethernet: 1x Intel® Gigabit NIC
- Audio: 7.1 Channel High Definition Audio + Optical
- Fan Headers: 6 PWM
- PCB: 8 Layers
Key Features
- Supports Intel Core X-series Cascade Lake-X and Skylake-X Processors
- Intel® Optane™ Memory Ready
- EVGA's Latest GUI BIOS Featuring OC Robot and In-BIOS Stress Testing
- Highly-Efficient 14 Phase Digital VRM
- Dual 8 Pin CPU Power
- 100% Solid State Capacitors
- 1x M.2 Key E (32mm) + 1x M.2 Key M (80mm)
- Reinforced PCIe and DIMM slots
- SPI flashing via USB allows you to flash your BIOS without a CPU
- Onboard Power, Reset, and Clear CMOS
- New Integrated EVGA WiFi/BT Module
- Included Intel Dual-band WiFi / BT4.2 with external antenna
- Intel VROC Support
- External Clock Gen.
- Onboard CPU Temp Monitor
