Introducing the EVGA H370 Stinger – a budget-friendly workhorse for your HTPC or gaming PC. Featuring a next-gen Intel® H370 Express Chipset with DDR4 2667MHz+ memory support and a 10-layer PCB, this motherboard is built to withstand the daily grind. Using a 9-Phase PWM, external clock generator, HDMI 2.0, and 7.1 Channel HD Audio, this motherboard will thrive as the heart of your next system, while supporting today’s widely-used components. With four SATA 6G ports, M.2, and is Intel® Optane™ Memory Ready, the H370 Stinger has you covered for storage. This motherboard also comes with USB 3.1 Gen 2, 4 native USB 3.1 Gen 1, and included Dual-band WiFi + Bluetooth for versatility. By using a careful balance of performance and features, the H370 Stinger gets you straight to the point.
One of the most important features of a mini-ITX is ensuring that you can connect to anything. Whether you need USB 2.0, USB 3.1 Gen 1, USB 3.1 Gen 2, the H370 Stinger features front panel headers of each type to make sure you can connect everything, including an EVGA CLC liquid CPU cooler.
A modern mini-iTX motherboard deserves modern amenities to connect your devices, displays, and audio. The H370 Stinger features HDMI 2.0, USB 3.1 Gen2, and the Realtek ALC1220 7.1 Channel audio controller on the rear panel for maximum convenience.
The H370 Stinger is designed to accommodate plenty of storage and connectivity options. Featuring four SATA III 6.0Gb/s ports and an Intel® Optane™ Ready M.2 Key-M slot on the back of the motherboard, you’ll have access to blazing fast data sources, as well as the speed and performance you expect from modern Intel® Desktop motherboards. The H370 Stinger also comes with the latest Intel® AC9560 WiFi/BT chips, as well as an Intel® i219V Gigabit NIC to ensure top speeds while gaming, streaming, or enjoying your favorite media.
With the EVGA H370 Stinger, you have the freedom to build any system you want, use it however you want, and enjoy it however you want.
Specifications
- Chipset: Intel H370
- Socket: 1151, Supports Intel Socket 1151 Processors
- Form Factor: mITX
- Memory: 2 DIMM Dual-Channel DDR4 2667MHz (up to 32GB)
- Display Outputs: 1x DP 1.2, 1x HDMI 2.0
- USB: 2x USB 3.1 Gen 2 (Type-A) / 1x USB 3.1 Gen 2 (Type-C via int. header) / 4x USB 3.1 Gen 1 (2 via int. header) / 4x USB 2.0 (2 via int. header)
- USB 3.1 (Internal Header): 1 Header / 2 Ports
- SATA: 4x SATA III 6Gb/s
- M.2 Key-M: 1x 80mm Slot (Up to 32Gb/s)
- M.2 Key-E: 1x 32mm Slot
- Ethernet: 1x Intel® Gigabit NIC / 1x Intel® AC9560 802.11AC WiFi
- Audio: 7.1 Channel HD + Optical
- Fan Headers: 3 (3 DC / PWM)
- PCB: 10 Layers
Key Features
- Supports Intel Core i3, i5, and i7 Socket 1151 Coffee Lake-S Processors
- Intel® Optane™ Memory Ready
- HDMI 2.0 and DisplayPort 1.2
- 7.1 Channel High Definition Audio + Optical
- Included Intel Dual-band WiFi / BT4.2 with external antenna
- 1x M.2 Key E (32mm) + 1x M.2 Key M (80mm on back)
- 100% Solid State Capacitors
- External Clock Gen.
- USB 3.1 Gen 2 Support
- USB 3.1 Gen 1 Support
- USB 2.0 Support
