The DG-7 Series
Gaming Case
Designed For Gamers
The mid-tower is the ideal form factor that is well balanced between usable space and overall footprint. DG-7 is a case designed with aesthetics and function in mind, and is the perfect mid-tower solution.
![DG-7](https://images.evga.com/articles/01157/dg7_article_header.jpg)
DG-7 Series Features
![tempered glass](https://images.evga.com/articles/01157/features/DG7_article_feature_01_EN.jpg)
![vertical gpu](https://images.evga.com/articles/01157/features/DG7_article_feature_02_EN.jpg)
![full rgb](https://images.evga.com/articles/01157/features/DG7_article_feature_03_EN.jpg)
![k-boost](https://images.evga.com/articles/01157/features/DG7_article_feature_04_EN.jpg)
Convenient and versatile to build
Built in Cable management, covered psu shroud, and hidden hard drive trays for a clean and easy build. Supports up to 7 case fans, fully compatible with 360mm, 280mm, 240mm, and 120mm radiators.
![Modualar Image](https://images.evga.com/articles/01157/cable_management_image.jpg)
Awesome Vertical GPU Support!
Vertical GPU support- DG-7 series supports vertical GPU mounting. In tandem with the beautiful tempered glass side panel, vertical GPU mounting is the perfect way to display your GPU.
![Vertical GPU](https://images.evga.com/articles/01157/vertical_gpu_image.jpg)
DG TUNER
Allows you to fully control the RGB lighting in your case.
![DG Tuner](https://images.evga.com/articles/01157/DGTune.jpg)
THE DG-7 SERIES GAMING CASE IS THE ULTIMATE PLATFORM
DG-7 is the perfect solution to the mid-tower case, it features convenient and easy cable management, wide range of radiator support, durable steel frame. The tempered glass side panel is perfect to show off your system, no matter if you go with traditional GPU mount or vertical GPU mount.
![Main Image](https://images.evga.com/articles/01157/cases/main_model_image_dg73.jpg)
EVGA DG-7 SERIES GAMING CASE
DG-73
![DG-73](https://images.evga.com/articles/01157/cases/dg-73_image.png)
BLACK
(130-P0-0020-KR)
$89.99
DG-75
![DG-75](https://images.evga.com/articles/01157/cases/dg-75_image.png)
BLACK
(150-B0-2020-KR)
$109.99
DG-75
![DG-75 WHITE](https://images.evga.com/articles/01157/cases/dg-75white_image.png)
WHITE
(156-F1-2022-KR)
$119.99
DG-76
![DG-76](https://images.evga.com/articles/01157/cases/dg-76_image.png)
BLACK
(160-B0-2230-KR)
$139.99
DG-76
![DG-76 WHITE](https://images.evga.com/articles/01157/cases/dg-76white_image.png)
WHITE
(166-W1-2232-KR)
$149.99
DG-77
![DG-77](https://images.evga.com/articles/01157/cases/dg-77_image.png)
BLACK
(170-B0-3540-KR)
$159.99
DG-77
![DG-77 WHITE](https://images.evga.com/articles/01157/cases/dg-77white_image.png)
WHITE
(176-W1-3542-KR)
$169.99
176-W1-3542-KR
DG-77 White
Specs at a Glance
- Form Factor: mITX,mATX,ATX
- Graphics Size Supported: 15.35in -390mm
- Material: Steel/ABS
- Width: 8.3in - 211mm
- Height: 18.78in - 477mm
- Depth: 19.01in - 483mm
- Drive Bays: 2x 2.5"/2x3.5"
- USB 3 Ports: 2
- HD Audio: In/Out
- Fans: 4 x 120mm
- Window: Yes
- Max Graphics Cards: 3
- KBoost: Yes
- Fan Size Support: 120/140mm
- LED Display: Yes
- Graphics Size Height Supported: 5.9in -150mm
Key Features
- 3 Year Warranty
- Adjustable RGB LED
- Built-in RGB Controller
- Cable Management
- Completely Removable PCI Brackets
- Flexible Fan Support
- K-Boost Button
- Optimized Airflow Path
- Removable Fan Filters
- Robust Water Cooling Support
- SSD and HDD support
- Tempered Glass Side Panels
- Vertical GPU Support
170-B0-3540-KR
DG-77 Black
Specs at a Glance
- USB 3 Ports: 2
- HD Audio: In/Out
- Fans: 4 x 120mm
- Window: Yes
- KBoost: Yes
- LED Display: Yes
Key Features
- 3 Year Warranty
- Cable Management
- K-Boost Button
166-W1-2232-KR
DG-76 White
Specs at a Glance
- USB 3 Ports: 2
- HD Audio: In/Out
- Fans: 3 x 120mm
- Window: Yes
- LED Display: Yes
Key Features
- 3 Year Warranty
- Cable Management
160-B0-2230-KR
DG-76 Black
Specs at a Glance
- USB 3 Ports: 2
- HD Audio: In/Out
- Fans: 3 x 120mm
- Window: Yes
- LED Display: Yes
Key Features
- 3 Year Warranty
- Cable Management
156-F1-2022-KR
DG-75 White
Specs at a Glance
- Depth: 18.50in - 470mm
- USB 3 Ports: 2
- HD Audio: In/Out
- Fans: 2 x 120mm
- Window: Yes
- LED Display: Yes
Key Features
- 3 Year Warranty
- Cable Management
150-B0-2020-KR
DG-75 Black
Specs at a Glance
- USB 3 Ports: 2
- HD Audio: In/Out
- Fans: 2 x 120mm
- Window: Yes
- LED Display: Yes
Key Features
- 3 Year Warranty
- Cable Management
130-P0-0020-KR
DG-73 Black
Specs at a Glance
- Width: 8.03in - 204mm
- Depth: 18.58in - 472mm
- USB 3 Ports: 2
- HD Audio: In/Out
- Fans: 2 x 120mm
- Window: Yes
- LED Display: Yes
Key Features
- 3 Year Warranty
- Cable Management
![Table](https://images.evga.com/articles/01157/table/dg7_series_comparison_chart_03_EN.png)
WORLD LEADING
![Warranty 3 Years](https://images.evga.com/articles/01157/warranty/3_year_warranty_EN.png)
