Powerful to the Core
Introducing the EVGA Z370 motherboards, based on Intel's Z370 Express Chipset and 8th Gen. CPUs. These motherboards are built to take mainstream performance to the next level...and beyond. This lineup includes not only the most commonly used ports, slots, and components, but also many surprises. All EVGA Z370 boards include cable cutouts to make tight fits and cabling a concern of the past. These boards also feature metal-reinforced PCIe and DIMM slots, 2-Way SLI Support, multiple RGB headers*, M.2 slots, Intel or Killer Gigabit NICs, and switchable dual-BIOS. Your ears will appreciate Realtek's upgraded 7.1 Channel audio or Creative's Sound Core 3D Audio for superior listening and gaming performance. No EVGA motherboard series would be complete without overclocking support: the Z370 Classified K and Micro ATX are both designed with an 8-Phase VCore design and an external clock gen. to provide more power and stability to your everyday life. Make an EVGA Z370 motherboard part of your next PC and find out just how powerful your system can be - starting from the core.
* Available only on the EVGA Z370 Classified K and Z370 Micro ATX
The EVGA Z370 motherboards feature designs engineered to enhance and improve your next build
- Intel 8th Generation Core i7/i5/i3 Coffee Lake-S Processors
- Discover the power of a 6 Core/12 Thread processor for the first time on an Intel Z-Series motherboard!
- Intel® Optane™ Memory Ready
- Accelerate your PC with Intel’s latest solutions for blistering fast boot times and increased performance for gaming and everyday tasks
- Reinforced PCIe and DIMM slots
- Use today's latest, greatest...and heaviest graphics cards and memory and still have Peace of Mind Gaming
- Dual BIOS chips on all EVGA Z370 motherboards
- Easily switch between BIOS configurations to use a custom BIOS, troubleshoot a problem, or fix a failed BIOS update!
- Optimized power connector layout for cable management
- All EVGA Z370 motherboards feature a new layout for some power connectors to avoid compatibility issues with cases and tight spaces
- Killer DoubleShot™ Pro*
- Killer DoubleShot™ Pro helps you maintain your network performance while gaming or streaming, so you won't miss any part of the action
- Integrated HDMI 2.0*
- The EVGA Z370 Classified K features an HDMI 2.0 port to allow 4K gaming or streaming at 60fps with supported Intel HD Graphics
- External Clock Generator**
- The EVGA Z370 Classified K and Micro ATX feature an external clock generator to improve overclocking stability and increase your overall performance
** Available only on the EVGA Z370 Classified K and Z370 Micro ATX
The EVGA Z370 Classified K packs the power, performance, and stability of EVGA's storied motherboards into a convenient ATX form factor. Featuring the next-gen Intel® Z370 Express Chipset and Intel's 8th Gen. CPUs, this motherboard is engineered to defy the expectations of the mainstream motherboard media. The Z370 Classified K features a 13 Phase Highly-Efficient Digital VRM to power Intel's 6-Core Coffee Lake-S CPUs. This board also features native HDMI 2.0 and Killer DoubleShot™ Pro, which balances network load to ensure your gaming or streaming goes uninterrupted. Connect all your peripherals with 8 USB 3.0, 4 USB 2.0, USB 3.1 Type-A/Type-C connectors, and fast charge your USB devices via an internal USB 3.1 header. Make use of three M.2 slots on the board to keep your data blazing fast with NVMe SSDs or Intel® Optane™ devices, and experience high-fidelity sound with Creative Sound Core3D 5.1 Audio. With the EVGA Z370 Classified K in your system, test the boundaries of today's latest technology and be confident to face tomorrow's next big thing.
Key Features
- 100% Solid State Capacitors
- 1x M.2 Key E (32mm) + 2x M.2 Key M (80mm)
- 2-Way SLI® Support + PhysX
- 3 Year Warranty
- EVGA GUI BIOS
- External Clock Gen.
- HDMI 2.0 and DisplayPort 1.2
- Highly-Efficient 13 Phase Digital VRM
- Killer E2500 NIC with DoubleShot Pro
- On-Board Power Button with Integrated Power Light
- On-Board Reset Button with Integrated HDD Activity Light
- RGB Header Support
- Supports Intel Core i3, i5, and i7 Socket 1151 Coffee Lake-S Processors
- Switchable Dual BIOS
- USB 3.1 Internal Header for USB Fast Charge Support
Coming Soon
Specifications
- Chipset: Intel Z370
- Socket: LGA1151, Supports Intel Socket LGA1151 Coffee Lake-S Processors
- Form Factor: ATX
- SLI: 2-Way SLI + PhysX
- Memory: 4 DIMM Dual-Channel DDR4 4133MHz+ (up to 64GB)
- Display Outputs: HDMI 2.0, DP1.2
- USB: 8x USB 3.0 / 4x USB 2.0
- USB 3.1 (Rear I/O): 1x USB 3.1 Type-A, Type-C
- USB 3.1 (Internal Header): 1x ASMedia (ASM3142)
- SATA: 6x SATA 6Gb/s
- M.2 Key-M: 2x 80mm Slots (Up to 32Gb/s)
- M.2 Key-E: 1x 32mm Slot
- Ethernet: 2x Killer Gigabit NIC w/ DoubleShot Pro
- Audio: Creative Sound Core3D 5.1 Channel HD + Optical
- Fan Headers: 6 PWM
- PCB: 6 Layers
The EVGA Z370 FTW has everything you need to upgrade and enjoy Intel’s latest 8th Gen Core i7/i5 processors. With the Z370 platform, high-performance gaming and powerful work machines are now more affordable than ever. Featuring 6 SATA ports, 10 USB 3.0 ports, USB 3.1 Type A and Type-C ports, multiple M.2 sockets, Intel® Optane™, 7.1 Channel Audio, and an Intel Gigibit NIC, this board is ready for storage, sound, and data whenever you want it. However, this board wouldn’t be FTW without a highly-efficient Digital VRM connected to an 11 Phase power design, 2-way SLI + PhysX support, Dual-BIOS support, and EVGA’s GUI BIOS. Whatever your passion, the EVGA Z370 FTW has the tools to get you there and the power to get the job done.
Key Features
- 3 Year Warranty
- EVGA GUI BIOS
- HDMI 1.4 and DP 1.2
- Highly-Efficient 11 Phase Digital VRM
- Onboard CPU Temperature Monitor
Coming Soon
Specifications
- Form Factor: ATX
- Display Outputs: HDMI 1.4, DP1.2
- USB: 10x USB 3.0 / 2x USB 2.0
- USB 3.1 (Rear I/O): 1x USB3.1 Type-A, Type-C
- Ethernet: Intel i219V Gigabit NIC
- Audio: Realtek ALC1220 7.1 Channel HD Audio + Optical
- PCB: 6 Layers
The Z370 Micro ATX ushers in the new era of Intel's mainstream motherboards with performance and features normally reserved for full-size motherboards. Supporting Coffee Lake-S, Intel’s 8th Generation Core processors, the Z370 Micro ATX can be driven by up to 6 physical cores + Hyper-Threading. This board contains standard features, including USB 3.0, M.2, Intel® Optane™ support, 7.1 Channel audio, reinforced PCI-e slots, an Intel Gigabit NIC and included Intel Dual-Band WiFi + Bluetooth. However, there is nothing standard about the Z370 Micro ATX’s overclocking ability. The Micro ATX features a Highly-Efficient Digital VRM, 8 VCORE phases, an External Clock Generator, and full EVGA E-LEET X support. Lastly, a board this powerful would not be complete without 2-Way SLI Support to ensure your dominance over the field. With the EVGA Z370 Micro ATX, mainstream performance just found its new home.
Key Features
- 3 Year Warranty
- Included Intel Dual-band WiFi / BT4.2 with external antenna
- Onboard Clear CMOS, Power and Reset Buttons
Coming Soon
Specifications
- Form Factor: mATX
- SLI: 2-Way SLI
- Memory: 2 DIMM Dual-Channel DDR4 4133MHz+ (up to 32GB)
- M.2 Key-M: 1x 80mm Slot (Up to 32Gb/s)
- Ethernet: 1x Intel® Gigabit NIC/1x Intel® 802.11AC WiFi + BT
- PCB: 6 Layers
134-KS-E379-KR
Coming Soon
Specifications
- Form Factor: ATX
- PCB: 6 Layers
EVGA Z370 FTW
134-KS-E377-KR
Coming Soon
Specifications
- Form Factor: ATX
- PCB: 6 Layers
EVGA Z370 Micro ATX
121-KS-E375-KR
Coming Soon
Specifications
- Form Factor: mATX
- SLI: 2-Way SLI
- PCB: 6 Layers
