EVGA GeForce GTX 1080 FTW2 and SC2
Now Available with 11GHz Memory*
+10% in Total Memory Bandwidth!
Asynchronous
Fan Control
A New and More
Efficient
Way to Cool
GPU fan determined by GPU temperature (Left Fan)
Power / Memory fan determined by Power / Memory temperature (Right Fan)
Full Control With
EVGA Precision XOC
Each sensor can be monitored in real time and displayed on PXOC OSD
Control the VGA and Power/Memory fans simultaneously or asynchronously
Interactive
Cooling With
Thermal LED Display System
User customized RGB color and visual alarm settings*
PeaceOfMind
Gaming
An EVGA ONLY fuse adds another layer of protection to your card and system.
Optimized Airflow
Fin Design
Fin holes direct airflow through fins
Half open fin maximizes airflow and L-shaped fins increase surface contact
Die Cast
Form Fitted Baseplate
And Backplate
Makes direct contact with all vital components.
Interlaced Pin Fin on Baseplate
Play Longer!
Overclock Better!
Interaction with other system devices*
* Coming Soon
