EVGA B3 Series Power Supplies
Introducing The EVGA B3 Power Supplies
EVGA Bronze power supplies have become synonymous with industry-leading stability, performance, and value. With the B3 power supplies, EVGA now adds fully modular cables, the ECO Intelligent Thermal Control System, even tighter voltage regulation (<2%), and a Long Life Sleeve Bearing Fan for ultra-quiet performance with an increased lifespan. Even more impressive, these power supplies continue to get shorter compared to its predecessors. Backed by EVGA's 5 Year Global Warranty, the EVGA B3 lineup will give you peace of mind for years to come.
Win EVGA B3 Power Supplies!
Join the evolution of the Bronze age.
Big Package, Small Size
No, it's not magic. Despite adding more features and increased performance, the EVGA B3 lineup is shorter than most of its competitors. At only 150mm long (450B3, 550B3, 650B3) and 160mm long (750B3, 850B3), you'll notice the extra space in your case, but you won't miss any performance or functionality.
Silence Doesn't Have To Be Golden
The EVGA B3 power supplies feature a Long Life Sleeve Bearing Fan, resulting in a quieter operation and a longer lifespan. Alternatively, flip on the EVGA ECO mode for fully silent operation at low to medium loads.
Next Gen Performance
Featuring models with 100% Japanese capacitors (750B3, 850B3), or models with a mainboard Japanese capacitor (450B3, 550B3, 650B3), the B3 lineup takes the already efficient B2 series and makes it even better with near-Silver efficiency and tighter voltage regulation (<2%). These power supplies have up to 88% efficiency!
Fully Modular Design
Use only the cables you need, reducing cable clutter and improving case airflow. Available on all B3 models.
Whisper Silent
EVGA ECO mode means the power supply is completely silent during low to medium loads. This is one quiet power supply!
450 B3 550 B3 650 B3 750 B3 850 B3
World Leading
5 Year Warranty
World leading warranty and support for 5 years.
EVGA 850 B3
220-B3-0850
Features
  • 5 Year Warranty and unparalleled EVGA Customer Support
  • 80 PLUS Bronze certified, with 85% efficiency or higher under typical loads
  • EVGA ECO Intelligent Thermal Control System eliminates fan noise at low to medium loads
Specs
  • OPP (Over Power Protection)
AC Input 100 - 240 VAC, 10A, 50 - 60 Hz
MAX Output 24A 24A 70.8A 0.5A 3.0A
849.6W
Combined 120W 849.6W 6W 15W
Output Power 850W @ +50C
EVGA 750 B3
220-B3-0750
Features
Specs
MAX Output 24A 24A 62.4A 0.5A 3.0A
748.8W
Combined 120W 748.8W 6W 15W
Output Power 750W @ +50C
EVGA 650 B3
220-B3-0650
Features
Specs
MAX Output 20A 20A 54.1A 0.5A 3.0A
649.2W
Combined 110W 649.2W 6W 15W
Output Power 650W @ +40C
EVGA 550 B3
220-B3-0550
Features
Specs
MAX Output 20A 20A 45.8A 0.5A 3.0A
549.6W
Combined 110W 549.6W 6W 15W
Output Power 550W @ +40C
EVGA 450 B3
220-B3-0450
Features
Specs
MAX Output 20A 20A 37.4A 0.5A 3.0A
448.8W
Combined 110W 448.8W 6W 15W
Output Power 450W @ +40C
