![](https://images.evga.com/articles/custom/back_to_top_arrow.png)
A new era in gaming
With Everything Detected
![EVGA iCX](https://images.evga.com/articles/01084/header/icx.png)
![EVGA iCX](https://images.evga.com/articles/01084/header/card.png)
![Green](https://images.evga.com/articles/01084/header/rgb/g_green.png)
![Blue](https://images.evga.com/articles/01084/header/rgb/g_blue.png)
![Green](https://images.evga.com/articles/01084/header/rgb/p_green.png)
![Blue](https://images.evga.com/articles/01084/header/rgb/p_blue.png)
![Green](https://images.evga.com/articles/01084/header/rgb/m_green.png)
![Blue](https://images.evga.com/articles/01084/header/rgb/m_blue.png)
PeaceOfMind Gaming
![EVGA GeForce](https://images.evga.com/articles/01084/header/geforce.png)
EVGA iCX Technology is not JUST a Cooler.
It is a combination of new PCB, Thermal Modules, LED and Precision XOC.
- Featuring a total of 11 global patents (pending and granted), iCX is efficiency perfected.
- 9 Additional Sensors and MCU’s embedded on the PCB.
- Purposefully-directed Airflow Chambers.
- Newly Designed Die-Cast Baseplate and Backplate.
- Full Control Using EVGA Precision XOC.
- EVGA’s iCX is the Very Definition of Interactive Cooling.
Why Was iCX Technology Created?
With PC gaming growing, it is important to provide "Peace of Mind Gaming" to the user. With EVGA’s new iCX technology, users can have a better understanding of their cards operation. This includes temperature monitoring on key components (not just GPU), interaction with other devices and better cooling with asynchronous fan control providing better overclocking capabilities.
With EVGA iCX technology, a new era of PC gaming is coming.
EVGA iCX Has
9
Thermal Sensors
& Multiple MCUs
All 9 sensors can be displayed in EVGA Precision XOC and OSD
Asynchronous
Fan Control
![Asynchronous Fan Control](https://images.evga.com/articles/01084/features/asynchronous.jpg)
A New and More
Efficient
Way to Cool
GPU fan determined by GPU temperature (Left Fan)
Power / Memory fan determined by Power / Memory temperature (Right Fan)
![Improved Cooling Efficiency](https://images.evga.com/articles/01084/features/efficient.png)
Full Control With
EVGA Precision XOC
Each sensor can be monitored in real time and displayed on PXOC OSD
Control the VGA and Power/Memory fans simultaneously or asynchronously
![EVGA Precision XOC](https://images.evga.com/articles/01084/features/pxoc.png)
Interactive
Cooling With
Thermal LED Display System
User customized RGB color and visual alarm settings*
PeaceOfMind
Gaming
An EVGA ONLY fuse adds another layer of protection to your card and system.
Optimized Airflow
Fin Design
Fin holes direct airflow through fins
Half open fin maximizes airflow and L-shaped fins increase surface contact
![Optimized Airflow Fin Design](https://images.evga.com/articles/01084/features/airflow.jpg)
Die Cast
Form Fitted Baseplate
And Backplate
Makes direct contact with all vital components.
Interlaced Pin Fin on Baseplate
Play Longer!
Overclock Better!
Interaction with other system devices
![Red](https://images.evga.com/articles/01084/features/reda.jpg)
![Green](https://images.evga.com/articles/01084/features/greenb.jpg)
![Blue](https://images.evga.com/articles/01084/features/bluea.jpg)
![Red](https://images.evga.com/articles/01084/features/redb.jpg)
![Green](https://images.evga.com/articles/01084/features/greena.jpg)
![Blue](https://images.evga.com/articles/01084/features/blueb.jpg)
EVGA GeForce GTX 1080 with iCX Technology
- CUDA Cores: 2560
- Base Clock: 1721 MHz
- Boost Clock: 1860 MHz
- 2-way SLI Ready
- Memory Bit Width: 256 Bit
- Memory Clock: 10010 MHz
- Memory Speed: 0.18 ns
- Memory Bandwidth: 320 GB/s
Key Features
- 10 Phase Power Design
- Adjustable RGB LED
- Asynchronous Fans
- EVGA Double BIOS
- EVGA iCX Technology
- Microsoft DirectX 12 API
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- NVIDIA GPU Boost 3.0
- OpenGL 4.6 Support
- VR Ready
- Vulkan API
- CUDA Cores: 2560
- Base Clock: 1607 MHz
- Boost Clock: 1733 MHz
- 2-way SLI Ready
Key Features
- Asynchronous Fans
- EVGA Double BIOS
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- VR Ready
- Vulkan API
- CUDA Cores: 2560
- Base Clock: 1708 MHz
- Boost Clock: 1847 MHz
- 2-way SLI Ready
- Memory Clock: 11016 MHz
- Memory Bandwidth: 352.6 GB/s
Key Features
- Asynchronous Fans
- NVIDIA G-SYNC
- VR Ready
- Vulkan API
- NVIDIA® Ansel
- NVIDIA GameStream
- CUDA Cores: 2560
- 2-way SLI Ready
Key Features
- Asynchronous Fans
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- VR Ready
- Vulkan API
- CUDA Cores: 2560
- 2-way SLI Ready
Key Features
- Asynchronous Fans
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- VR Ready
- Vulkan API
EVGA GeForce GTX 1070 with iCX Technology
- CUDA Cores: 1920
- Boost Clock: 1797 MHz
- 2-way SLI Ready
- Memory Clock: 8008 MHz
- Memory Speed: 0.25 ns
Key Features
- Asynchronous Fans
- EVGA Double BIOS
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- VR Ready
- Vulkan API
- CUDA Cores: 1920
- Base Clock: 1506 MHz
- Boost Clock: 1683 MHz
- 2-way SLI Ready
Key Features
- Asynchronous Fans
- EVGA Double BIOS
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- VR Ready
- Vulkan API
- CUDA Cores: 1920
- Base Clock: 1594 MHz
- Boost Clock: 1784 MHz
- 2-way SLI Ready
Key Features
- Asynchronous Fans
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- VR Ready
- Vulkan API
- CUDA Cores: 1920
- 2-way SLI Ready
Key Features
- Asynchronous Fans
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- VR Ready
- Vulkan API
EVGA GeForce GTX 1060 with iCX Technology
- CUDA Cores: 1280
- Base Clock: 1632 MHz
- Memory Bit Width: 192 Bit
Key Features
- Asynchronous Fans
- NVIDIA® Ansel
- NVIDIA G-SYNC Ready
- VR Ready
- Vulkan API
- CUDA Cores: 1280
- Boost Clock: 1708 MHz
Key Features
- Asynchronous Fans
- NVIDIA® Ansel
- VR Ready
- Vulkan API
- CUDA Cores: 1280
- Boost Clock: 1835 MHz
Key Features
- Asynchronous Fans
- NVIDIA® Ansel
- VR Ready
- Vulkan API
- CUDA Cores: 1280
Key Features
- Asynchronous Fans
- NVIDIA® Ansel
- VR Ready
- Vulkan API
- CUDA Cores: 1152
- Memory Detail: 3072 MB GDDR5
Key Features
- Asynchronous Fans
- NVIDIA® Ansel
- VR Ready
- Vulkan API
- CUDA Cores: 1152
Key Features
- Asynchronous Fans
- NVIDIA® Ansel
- VR Ready
- Vulkan API
