![Back To Top](https://images.evga.com/articles/01047/back_to_top_arrow.png)
![EVGA GeForce GTX 1060 3GB ACX 3.0](https://images.evga.com/articles/01047/header/gtx_1060_heading.png)
![EVGA GeForce GTX 1060 3GB ACX 3.0 Card](https://images.evga.com/articles/01047/header/gtx_1060.png)
![Precision XOC](https://images.evga.com/articles/01047/header/precisionx_oc.png)
The EVGA GeForce GTX 1060 3GB graphics cards are loaded with innovative new gaming technologies, making it the perfect choice for the latest high-definition games. Powered by NVIDIA Pascal – the most advanced GPU architecture ever created – the GeForce GTX 1060 3GB delivers brilliant performance that opens the door to virtual reality and beyond.
These cards also feature EVGA ACX cooling technology. EVGA ACX once again brings new and exciting features to the award winning EVGA ACX cooling technology. SHP gives increased heatpipes and copper contact area for cooler operation, and optimized fan curve for even quieter gaming. Of course, ACX coolers also feature optimized swept fan blades, double ball bearings and an extreme low power motor, delivering more airflow with less power, unlocking additional power for the GPU.
EVGA GeForce GTX 1060 3GB SC
Small Size, Huge Performance
![GTX 1060 3GB vs. GTX 970](https://images.evga.com/articles/01047/versus/chart.jpg)
![EVGA Precision XOC Unlocks the Power of Pascal](https://images.evga.com/articles/01047/precisionxoc/precisionxoc_heading_2.png)
![Define your game with EVGA Precision XOC](https://images.evga.com/articles/01047/precisionxoc/define_your_game_2.png)
![](https://images.evga.com/articles/01047/bearings/bearings_heading.png)
EVGA ACX fans use double ball bearings, which offer 4X longer lifespan than the sleeve bearing fans used by competitors. The oil that is used in sleeve bearing fans makes them vulnerable and prone to failure after time when the oil dries up. Upgrade to EVGA ACX and your card will go the distance!
![](https://images.evga.com/articles/01047/bearings/bearings_image.png)
![](https://images.evga.com/articles/01047/overclocking/overclocking_heading.png)
Did you know that power consumption of the fans can directly affect your maximum overclock? The maximum “power target” takes into account the fan power consumption, meaning the lower the power consumption from the fan, the more power available for the card. EVGA ACX coolers use more than 4X lower power than competitors allowing for better and more stable overclocks.
![](https://images.evga.com/articles/01047/overclocking/087.png)
![](https://images.evga.com/articles/01047/overclocking/088.png)
![](https://images.evga.com/articles/01047/overclocking/382.png)
![](https://images.evga.com/articles/01047/overclocking/383.png)
![](https://images.evga.com/articles/01047/overclocking/evga-acx.png)
![](https://images.evga.com/articles/01047/overclocking/brand_a.png)
![](https://images.evga.com/articles/01047/overclocking/over-4x.png)
![](https://images.evga.com/articles/01047/overclocking/lower-fan-power.png)
![Introducing EVGA ACX 3.0](https://images.evga.com/articles/01047/cooling/acx3_heading.png)
![ACX 3.0 Cooling](https://images.evga.com/articles/01047/cooling/1060_exploded_EN.jpg)
- CUDA Cores: 1152
- Base Clock: 1632 MHz
- Boost Clock: 1860 MHz
- Memory Detail: 3072 MB GDDR5
- Memory Bit Width: 192 Bit
- Memory Clock: 8008 MHz
- Memory Speed: 0.25 ns
Key Features
- EVGA ACX 3.0 Cooling
- Microsoft DirectX 12 API
- NVIDIA® Ansel
- NVIDIA G-SYNC Ready
- NVIDIA GPU Boost 3.0
- OpenGL 4.6 Support
- PCI Express 3.0
- VR Ready
- Vulkan API
- CUDA Cores: 1152
- Base Clock: 1607 MHz
- Boost Clock: 1835 MHz
- Memory Bandwidth: 192 GB/s
Key Features
- NVIDIA® Ansel
- PCI Express 3.0
- VR Ready
- Vulkan API
- CUDA Cores: 1152
Key Features
- NVIDIA® Ansel
- PCI Express 3.0
- VR Ready
- Vulkan API
- CUDA Cores: 1152
- Base Clock: 1506 MHz
- Boost Clock: 1708 MHz
Key Features
- NVIDIA® Ansel
- PCI Express 3.0
- VR Ready
- Vulkan API
