The EVGA SC17 1070 Gaming Laptop has arrived. This 4K ready, high performance laptop was meticulously created from the ground up for the hardcore gamer, performance enthusiast, and even overclocker. No shortcuts here.
It all starts with power, an in house EVGA designed power supply with a new unique form factor helps deliver up to 240 watts of power when needed, without compromising battery life.
An Intel Core i7 6820HK CPU that is unlocked and capable of being overclocking to 3800MHz and beyond, combined with an NVIDIA GeForce GTX 1070, also capable of being overclocked, lets you get the performance you always wanted from a gaming laptop.
Did we mention that the EVGA SC17 1070 Gaming Laptop is built for overclocking? A FULL GUI BIOS with full mouse control gives you complete control over all aspects of performance, voltage and advanced settings right at your fingertips. Not to mention, a Clear CMOS button directly on the chassis, this is the world's first TRUE overclocking laptop.
A sleek design rounds out the package with a full unibody chassis, and slim design that is under 1.07in at its thickest point. This is just the beginning. USB 3.1 Type C, excellent sound, and a beautiful 4K 17” display is what you get when you cross performance with art.
The World's First Gaming Laptop Built for Enthusiasts
Now available with
NVIDIA G-SYNC Technology
NVIDIA G-SYNC gives you more of what you want in a gaming experience with smooth, tear-free gameplay.
Gaming Unleashed
Unleash your gaming dominance with the new GeForce GTX 1070 GPU that turn your mobile rig into a sleek, high-performance gaming weapon-powered by the game-changing NVIDIA Pascal architecture.
- 2048 NVIDIA CUDA Cores
- 1442 MHz Base Clock
- 1645 MHz Boost Clock
- 8GB 8000MHz GDDR5 Memory
Unibody Design
An aluminum unibody design and thin 1.07in thickness mean this is one of the sleekest laptops around.
4K UHD Display
An IPS display capable of delivering up to 4K resolution for crystal clear graphics.
Incredible Hardware
EVGA is known for performance hardware, and the EVGA SC17 1070 laptop is no exception. An Intel Core i7 6820HK Unlocked processor combined with an NVIDIA GeForce GTX 1070 graphics gives you unbelievable performance in the latest games.
Built To Overclock
Overclocking on a laptop? Seems like a myth, but we have nothing to hide here. A full GUI BIOS with full control over CPU Multipliers, Voltage, Memory Timings, Frequency, even GPU overclocking right inside of the BIOS. It also ships with EVGA PrecisionX mobile for complete control in Windows also!
BIOS
The EVGA SC17 1070 Gaming Laptop ships with a REAL BIOS. This means full GUI support including mouse, complete control over all overclocking features such as CPU.
Overclocking at your fingertips, overclock on the fly with up/down arrow keys allowing you to enable Superclocked performance, or downclock mode to improve battery life. Also cycle through preset overclocks to find the best performance for the situation.
Enable Superclock Mode to Boost Performance
3DMark Fire Strike Performance
With EVGA EOC you can boost your performance with the push of a button
Specs
CPU
GPU
NVIDIA GeForce GTX 1070 8GB GDDR5
32GB G.Skill 2666MHz DDR4 SO-DIMM (16GBx2)
Display
17.3 UHD 4K (3840x2160/60Hz)
Storage
256GB M.2 NVMe PCIe SSD + 1TB 7200RPM SATA 6G
Video Out
1x HDMI, 2x Mini DisplayPort
Wi-Fi
Intel Snowfield Peak AC-8260
Clear CMOS
Clear CMOS button located directly on chassis, this is a true overclocking laptop!
Ethernet
Intel 219-V 10/100/1000 Controller (RJ45)
USB
2x USB 3.0 Type A, 1x USB 3.1 Type C
Audio
Realtek ALC 255, 3.5mm Headphone/Mic
Webcam
Full HD 1920x1080
Touchpad
Synaptics Clickpad 1.5
Bluetooth
Bluetooth 4.2
Keyboard
Full sized white backlit
Weight
9.0389lbs (4.10kg)
Dimensions
16.06in - 408mm x 11.63in - 295.5mm x 1.07in - 27.18mm
Windows 10 Home 64bit Edition
Version 1607EVGA PrecisionX Mobile
for EVGA SC17 1070 Gaming Laptop
The power of EVGA PrecisionX, now mobile with EVGA PrecisionX Mobile. Tweak your overclock settings, overclock hotkeys, profiles and CPU overclocking right at your fingertips. EVGA PrecisionX mobile can even enable/disable laptop backlighting and keyboard lighting!
Learn more and download it here.
