![Back To Top](https://images.evga.com/articles/01018/back_to_top_arrow.png)
![](https://images.evga.com/articles/01018/header/evga.png)
![](https://images.evga.com/articles/01018/header/dg-8_EN.png)
![](https://images.evga.com/articles/01018/header/text_EN.png)
![](https://images.evga.com/articles/01018/header/case.png)
Introducing the EVGA DG-8 line of full-tower cases. These cases are built for the enthusiast with an optimized airflow path that gives you dedicated cooling fans for your graphics cards, a K-Boost button that automatically boosts fanspeed and CPU/GPU, a built in fan controller and much more. These new line of cases are the ultimate platform for any gaming or graphics enthusiast. With these features and more, it is easy to see how DG means Designed for Gaming!
PREORDERS HAVE ENDED
Features
EVGA DG-8 Gaming Cases
100-E1-1014
EVGA DG-86
Key Features
- 3 Year Warranty
- Built in Fan Controller + Temperature Sensor
- Cable Management
- Completely Removable PCI Brackets
- Easy Access to I/O ports and Clean Cable Output
- Easy Removable Door
- Flexible Fan Support
- Front and Top Facing Power, Reset Buttons and USB 2.0. Front Facing USB 3.1 Type-C, and HDMI
- GPU Airflow Channel
- K-Boost Button
- Optimized Airflow Path
- Optional Segmented PSU Tray Hides Cables
- Removable Fan Filters
- Robust Water Cooling Support
- Supports up to 12 SSD/HDD
100-E1-1000
EVGA DG-85
Key Features
- 3 Year Warranty
- Cable Management
- K-Boost Button
100-E2-1000
EVGA DG-84
Key Features
- 3 Year Warranty
- Cable Management
- K-Boost Button
EVGA DG-8 Series Comparison Chart
Case Name | EVGA DG-87 | EVGA DG-86 | EVGA DG-85 | EVGA DG-84 |
MSRP | $229.99 | $199.99 | $169.99 | $149.99 |
Window Panel | Yes | Yes | Yes | No |
Finish | Metallic Gunmetal Grey | Gunmetal Grey | Gunmetal Grey | Matte Black |
Form Factor Support | mITX/mATX/ATX/E-ATX | mITX/mATX/ATX/E-ATX | mITX/mATX/ATX/E-ATX | mITX/mATX/ATX/E-ATX |
Max Graphics Cards | 4 | 4 | 4 | 4 |
I/O Ports (Top)
Power | 1 | 1 | 1 | 1 |
Reset | 1 | 1 | 1 | 1 |
K-Boost | 1 | 1 | 1 | 1 |
USB 2.0 | 2 | 2 | 2 | 2 |
I/O Ports (Front)
USB 3.0 | 2 | 2 | 2 | 2 |
USB 3.1 Type-C | 1 | 1 | 0 | 0 |
HDMI | 1 | 1 | 1 | 1 |
Audio (Headphone) | 1 | 1 | 1 | 1 |
Audio (Mic) | 1 | 1 | 1 | 1 |
Storage Support
Max SSD/HDD Supported | 12 | 12 | 4 | 4 |
2.5in SSD | 12 | 12 | 4 | 4 |
3.5in HDD | 8 | 8 | 2 | 2 |
Fans
Fan Controller | Yes (Software+Buttons) | Yes (Software) | No | No |
Fan Size | 140mm (Default), 120mm (Option) | 140mm (Default), 120mm (Option) | 140mm (Default), 120mm (Option) | 140mm (Default), 120mm (Option) |
Max Fan Support | Top x 3, Right x 3, Left x 2 | Top x 3, Right x 3, Left x 2 | Top x 3, Right x 3, Left x 2 | Top x 3, Right x 3, Left x 2 |
Included Fans | Top x 1, Right x 3, Left x 2 | Top x 0, Right x 2, Left x 2 | N/A | N/A |
Temperature Sensor | Yes | Yes | N/A | N/A |
LED Display | Yes | Yes | N/A | N/A |
Water Cooling Bracket | Yes | Yes | N/A | N/A |
Case Size (LxWxH) | 686x270x642.45mm | 686x270x642.45mm | 686x270x642.45mm | 686x270x642.45mm |
Individual Shipper Size | 740x372x800mm | 740x372x800mm | 740x372x800mm | 740x372x800mm |
Case Weight (lb/kg) | 43.2lb/19.6kg | 43.2lb/19.6kg | 37.5lb/17.0kg | 38.4lb/17.4kg |
Gross Weight | 51.1lb/23.2kg | 51.1lb/23.2kg | 43.4lb/19.7kg | 44.3lb/20.1kg |
