![Back To Top](https://images.evga.com/articles/01017/back_to_top_arrow.png)
![EVGA GeForce GTX 1070 ACX 3.0](https://images.evga.com/articles/01017/header/gtx_1070_heading.png)
![EVGA GeForce GTX 1070 ACX 3.0 Card](https://images.evga.com/articles/01017/header/gtx_1070.png)
![Precision XOC](https://images.evga.com/articles/01017/header/precisionx_oc.png)
![VR Ready](https://images.evga.com/articles/01017/header/vr_ready.jpg)
The EVGA GeForce GTX 1070 featuring EVGA ACX 3.0 cooling is here. This new graphics card features NVIDIA’s new “Pascal” graphics processor which is the most advanced gaming GPU ever created. This breakthrough GPU delivers industry-leading performance, innovative new gaming technologies, and immersive, next-gen VR.
These cards also feature EVGA ACX 3.0 cooling technology. EVGA ACX 3.0 once again brings new and exciting features to the award winning EVGA ACX cooling technology. SHP 3.0 gives increased heatpipes and copper contact area for cooler operation, and optimized fan curve for even quieter gaming. Of course, ACX 3.0 coolers also feature optimized swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU. Select EVGA ACX 3.0 models will even feature a 10CM fan and RGB LED, allowing complete control over the color from EVGA Precision XOC.
![EVGA Precision XOC Unlocks the Power of Pascal](https://images.evga.com/articles/01017/precisionxoc/precisionxoc_heading_2.png)
![Define your game with EVGA Precision XOC](https://images.evga.com/articles/01017/precisionxoc/define_your_game_2.png)
![Introducing EVGA ACX 3.0](https://images.evga.com/articles/01017/cooling/acx3_heading.png)
![ACX 3.0 Cooling](https://images.evga.com/articles/01017/cooling/cooling.jpg)
![Adjustable RGB LED](https://images.evga.com/articles/01017/custom_colors/rgb_heading.png)
* Available on select models
![](https://images.evga.com/articles/01017/custom_colors/LED.gif)
![](https://images.evga.com/articles/01017/bearings/bearings_heading.png)
![](https://images.evga.com/articles/01017/bearings/bearings_image.png)
![](https://images.evga.com/articles/01017/overclocking/overclocking_heading.png)
Did you know that power consumption of the fans can directly affect your maximum overclock? The maximum “power target” takes into account the fan power consumption, meaning the lower the power consumption from the fan, the more power available for the card. EVGA ACX 3.0 coolers use more than 4X lower power than competitors allowing for better and more stable overclocks.
![](https://images.evga.com/articles/01017/overclocking/087.png)
![](https://images.evga.com/articles/01017/overclocking/088.png)
![](https://images.evga.com/articles/01017/overclocking/382.png)
![](https://images.evga.com/articles/01017/overclocking/383.png)
![](https://images.evga.com/articles/01017/overclocking/evga-acx-3.png)
![](https://images.evga.com/articles/01017/overclocking/brand_a.png)
![](https://images.evga.com/articles/01017/overclocking/over-4x.png)
![](https://images.evga.com/articles/01017/overclocking/lower-fan-power.png)
![](https://images.evga.com/articles/01017/memory/memory_heading.png)
![](https://images.evga.com/articles/01017/memory/memory_chip.png)
8GB of high performance memory running at extreme Clockspeeds giving you access to higher texture qualities in games and improved 4K gaming performance. Did we mention that this memory is running at an extreme 8,000MHz out of the box??!!
- CUDA Cores: 1920
- Base Clock: 1607 MHz
- Boost Clock: 1797 MHz
- 2-way SLI Ready
- Memory Detail: 8192 MB GDDR5
- Memory Bit Width: 256 Bit
- Memory Clock: 8008 MHz
- Memory Speed: 0.25 ns
Key Features
- 10 Phase Power Design
- Adjustable RGB LED
- EVGA ACX 3.0 Cooling
- EVGA Double BIOS
- Microsoft DirectX 12 API
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- NVIDIA GPU Boost 3.0
- OpenGL 4.6 Support
- PCI Express 3.0
- VR Ready
- Vulkan API
- CUDA Cores: 1920
- Base Clock: 1594 MHz
- Boost Clock: 1784 MHz
- 2-way SLI Ready
Key Features
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- PCI Express 3.0
- VR Ready
- Vulkan API
- CUDA Cores: 1920
- Base Clock: 1506 MHz
- Boost Clock: 1683 MHz
- 2-way SLI Ready
Key Features
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- PCI Express 3.0
- VR Ready
- Vulkan API
- CUDA Cores: 1920
- 2-way SLI Ready
Key Features
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- PCI Express 3.0
- VR Ready
- Vulkan API
EVGA GeForce GTX 1070 Comparison Chart
![](https://images.evga.com/articles/01017/products/comparison_EN.jpg)
