Built for VR
The EVGA GeForce GTX 980 Ti VR EDITION has arrived. Accelerated by the groundbreaking NVIDIA Maxwell architecture, the GTX 980 Ti delivers an unbeatable 4K and virtual reality experience. With 2816 NVIDIA CUDA Cores and 6GB of GDDR5 memory, it has the horsepower to drive whatever comes next. And with the VR EDITION, you get an included 5.25” drive bay with front HDMI 2.0 and USB 3.0 giving you easy access to your VR device’s input. The graphics card also has an internal HDMI connector, meaning no external cables will be visible.
Connects to 5.25" Drive Bay, no visible external wires!
Remark:
* Versus Competitors' Dual Fan Solution.
** When GPU Temperature < 60°C
*** Versus Reference Fan
Run Longer, Play Longer with EVGA ACX 2.0+
6GB of High Performance memory running at extreme clockspeeds giving you access to higher texture qualities in games, improved 4K gaming performance and optimized for the next generation of gaming.
Key Features
- dB Inverter
- EVGA ACX 2.0 Cooling
- Memory MOSFET Cooling Plate
- NVIDIA G-SYNC Ready
- NVIDIA GameWorks Technology
- NVIDIA GPU Boost 2.0
- NVIDIA MFAA Technology
- NVIDIA SLI Ready
- NVIDIA Surround Technology
- OpenCL Support
- OpenGL 4.6 Support
- PCI Express 3.0 x16
- Straight Heat Pipes
- CUDA Cores: 2816
- Base Clock: 1000 MHz
- Boost Clock: 1076 MHz
- Memory Bit Width: 384 Bit
- Memory Clock: 7010 MHz
- Memory Speed: 0.28 ns
Key Features
- 5.25" Drive Bay with Front HDMI 2.0 and USB 3.0
- NVIDIA SLI Ready
- OpenCL Support
- CUDA Cores: 2816
EVGA GeForce GTX 980 Ti VR EDITION Comparison Chart
EVGA PrecisionX – Redesigned to harness the power of GPU Boost 2.0, EVGA PrecisionX sets another baseline for what overclocking software should be. Learn more and download it here.
Key Features
- Temperature Target Control
- Pixel Clock Overclocking
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 980 Ti VR EDITION vitals. Learn more and download it here.
Key Features
- CPU Burn In Module
- Built-in log functionality
