EVGA SuperNOVA 650 G2 and 550 G2 Power Supplies
Unbeatable Performance
The unbeatable performance of the EVGA SuperNOVA G2 power supply line is now available in 650 and 550 watt versions. Based on the award winning G2 power supplies, these units feature 80 Plus Gold rated efficiency, and clean, continuous power to every component. The ECO Control Fan system offers fan modes to provide absolutely zero fan noise during low to medium load operations. Backed by an award winning 7 year warranty, and 100% Japanese capacitor design, the EVGA SuperNOVA 650/550 G2 power supplies offer unbeatable performance at an unbeatable value.
Features
- Ultra Quiet Fan with ECO Intelligent Thermal Control Fan system (Zero Fan Noise < 45°C)
- Unbeatable EVGA 7 Year Warranty and unparalleled EVGA Customer Support.
Specs
- OPP (Over Power Protection)
MAX Output | 24A | 22A | 54.1A | 0.5A | 3.0A |
649.2W | |||||
Combined | 110W | 649.2W | 6W | 15W | |
Output Power | 650W @ +50C |
Features
Specs
MAX Output | 22A | 22A | 45.8A | 0.5A | 3.0A |
549.6W | |||||
Combined | 110W | 549.6W | 6W | 15W | |
Output Power | 550W @ +50C |
100% Modular Design
FULL modularity enables you to use only the cables you need, helping to improve case airflow, eliminate unnecessary wires, and best of all, reduce cable clutter.
Whisper Silent
The EVGA ECO mode feature ensures that the power supply stays completely silent during low to medium loads. The fan does not spin until necessary, allowing for completely silent operation!
90% efficiency or higher under typical loads and highest quality Japanese brand capacitors ensure long-term reliability.
Features
Single +12V Rail
A single +12V rail offers the best power output, rail stability and compatibility with the latest hardware. EVGA SuperNOVA 650/550 G2 provides up to 54.1A/45.8A respectively on a single rail!
LLC Resonant Circuit Layout
Full DC to DC, LLC resonant circuit design improves efficiency.
Fully Modular
Fully modular design allows every single cable to be removed from the power supply for ease of installation and removal. You can also leave off unnecessary cables to reduce case clutter and maximize case airflow.
NVIDIA SLI Ready
Run multiple NVIDIA graphics cards for the ultimate gaming experience. The SuperNOVA 650/550 G2 gives you the power you need to drive these demanding systems and achieve the best overclocks.
Highest Quality Japanese Nippon Chemi-Con Solid State Capacitors
Gold Rated Efficiency
80 Plus certification ensures your power supply isn’t wasting power and turning it into excess heat. Under typical load this power supply is 90% efficient or higher.
