![Back To Top](https://www.evga.com/articles/00920/images/back_to_top_arrow.png)
![EVGA GeForce GTX 980 HYBRID](https://www.evga.com/articles/00920/images/header/980-Hybrid-Header-PD.png)
![EVGA GeForce GTX 980 HYBRID](https://www.evga.com/articles/00920/images/header/EVGA-GeForce-980-Hybrid.png)
Cooler than the Competition
Introducing the EVGA GeForce GTX 980 HYBRID, an "all in one" water cooling solution that significantly lowers the GPU operating temperature. Best of all? The water cooler is completely self-contained, with an included 120mm radiator and fan. No filling, no custom tubing, no maintenance. Just plug in and play! The EVGA GTX 980 HYBRID is available as a complete unit, or upgrade kit.
Of course, the GeForce GTX 980 HYBRID is also powered by the next-generation NVIDIA Maxwell architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features. Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next-generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing.
![](https://www.evga.com/articles/00920/images/cooling/GPU-Cooling.jpg)
- CUDA Cores: 2048
- Base Clock: 1291 MHz
- Boost Clock: 1393 MHz
- Memory Bit Width: 256 Bit
- Memory Clock: 7010 MHz
- Memory Speed: 0.28 ns
Key Features
- NVIDIA GameWorks Technology
- NVIDIA G-SYNC Ready
- NVIDIA GPU Boost 2.0
- NVIDIA MFAA Technology
- NVIDIA SLI Ready
- NVIDIA Surround Technology
- OpenCL Support
- OpenGL 4.4 Support
- PCI Express 3.0 x16
Key Features
- Built in 120mm radiator and fan helps dissipate the heat keeping the GPU as cool as possible. Fan can also be swapped or customized.
- Compatible with all "reference" style graphics cards.
- VRM and Memory cooling solution separated from GPU, allowing for the lowest GPU temperatures, and efficient VRM and Memory cooling.
Key Features
- Temperature Target Control
- Pixel Clock Overclocking
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 980 HYBRID vitals. Learn more and download it here.
Key Features
- CPU Burn In Module
- Built-in log functionality
