Looking to purchase an EVGA SuperNOVA GS or PS Power Supply? Here is another great reason to: EVGA is offering a FREE warranty extension to 7 Years on GS and PS models! All you need to do is register your EVGA SuperNOVA GS or PS Power Supply, and the extended warranty will automatically be added to your EVGA account.
The EVGA SuperNOVA GS and PS Power Supply line follow the EVGA tradition of uncompromised power and performance, so we upped the ante and made it nearly SILENT. The GS/PS series of PSU’s offer superior performance, Gold and Platinum level efficiency and extremely low noise levels making it the perfect PSU for a sound conscious environment.
Learn more about the EVGA SuperNOVA GS/PS Power Supplies http://www.evga.com/articles/00873/EVGA-SuperNOVA-850-1050-GS-1000-PS-Power-Supplies/
Qualifying EVGA SuperNOVA Power Supplies
SILENT Operation During Low to Normal Loads
EVGA ECO Mode enables silent operation under low to normal loads, generating 0dB of noise. The fan turns on only when necessary, keeping your system cool and quiet.
Single +12V Rail
A single +12V rail offers the best power output, rail stability and compatibility with the latest hardware. EVGA SuperNOVA 850GS/1050GS/1000PS provides up to 70A/87A/83A respectively on a single rail!
LLC Resonant Circuit Layout
Full DC to DC, LLC resonant circuit design improves efficiency.
Fully Modular
Fully modular designs allows every single cable to be removed from the power supply for ease of installation and removal. You can also leave off unnecessary cables to reduce case clutter and maximize case airflow.
NVIDIA SLI Ready
Run multiple NVIDIA graphics cards for the ultimate gaming experience. The SuperNOVA 850/1050 GS and 1000 PS gives you the power you need to drive these demanding systems and achieve the best overclocks.
Highest Quality Japanese Nippon Chemi-Con Solid State Capacitors
Teflon Nano-Steel Bearing
High quality Teflon Nano-Steel bearing ensures long life and nearly silent operation.
