![](https://www.evga.com/articles/00895/images/back_to_top_arrow.png)
EVGA GeForce GTX 960 SuperSC ACX 2.0+
Fine-Tuned to Perfection
![EVGA GeForce GTX 960](https://www.evga.com/articles/00895/images/960_card.png)
Part Number: 02G-P4-2966-KR
The EVGA GeForce GTX 960 delivers incredible performance, power efficiency, and gaming technologies that only NVIDIA Maxwell technology can offer. This is the perfect upgrade, offering 60% faster performance and twice the power efficiency of previous-generation cards*. Plus, it features VXGI for realistic lighting, support for smooth, tear-free NVIDIA G-SYNC technology, and Dynamic Super Resolution for 4K-quality gaming on 1080P displays.
The new EVGA ACX 2.0+ cooler brings new features to the award winning EVGA ACX 2.0 cooling technology. A Memory MOSFET Cooling Plate (MMCP) reduces MOSFET temperatures up to 11°C, and optimized Straight Heat Pipes (SHP) reduce GPU temperature by an additional 5°C. ACX 2.0+ coolers also feature optimized Swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU.
*Compared to GTX 660
Reviews
What does this all mean?
- Improved Cooling
- Reduced Fan Noise
- Better Overclocking
Why Double Ball Bearings?
EVGA ACX 2.0+ fans use double ball bearings, which offer 400% longer lifespan than the sleeve bearing fans used by competitors. The oil that is used in Sleeve bearing fans makes them vulnerable and prone to failure after time when the oil dries up. Upgrade to EVGA ACX 2.0+ and your card will go the distance!
![EVGA GeForce GTX 960 Fan Chart](https://www.evga.com/articles/00895/images/fan_comparison.jpg)
Run Longer, Play Longer with EVGA ACX 2.0+
EVGA ACX 2.0+ Means Better Overclocking
Did you know that power consumption of the fans can directly affect your maximum overclock? The maximum "power target" takes into account the fan power consumption, meaning the lower the power consumption from the fan, the more power available for the card. EVGA ACX 2.0+ coolers use over 4X lower power than competitor's allowing for better and more stable overclocks. In some cases, just a few watts of additional power for the card can provide an additional headroom of up to +25MHz higher GPU or +350MHz memory frequency!
![](https://www.evga.com/articles/00895/images/power_chart/960_power_chart_evga_87.png)
![](https://www.evga.com/articles/00895/images/power_chart/960_power_chart_evga_88.png)
![](https://www.evga.com/articles/00895/images/power_chart/960_power_chart_a_382.png)
![](https://www.evga.com/articles/00895/images/power_chart/960_power_chart_a_383.png)
Lower Fan Power = More Power for Overclocking
ACX 2.0+ Video Overview
- CUDA Cores: 1024
- Base Clock: 1304 MHz
- Boost Clock: 1367 MHz
- 2-way SLI Ready
- Memory Bit Width: 128 Bit
- Memory Clock: 7010 MHz
- Memory Speed: 0.28 ns
Key Features
- dB Inverter
- EVGA ACX 2.0 Cooling
- EVGA Backplate
- Memory MOSFET Cooling Plate
- NVIDIA G-SYNC Ready
- NVIDIA GameWorks Technology
- NVIDIA GPU Boost 2.0
- NVIDIA MFAA Technology
- NVIDIA SLI Ready
- NVIDIA Surround Technology
- OpenCL Support
- OpenGL 4.4 Support
- Optimized Power Target
- PCI Express 3.0 x16
- Quick Switch Dual BIOS
- Straight Heat Pipes
- CUDA Cores: 1024
- Base Clock: 1279 MHz
- Boost Clock: 1342 MHz
- 2-way SLI Ready
Key Features
- dB Inverter
- NVIDIA SLI Ready
- OpenCL Support
- CUDA Cores: 1024
- Base Clock: 1127 MHz
- Boost Clock: 1178 MHz
- 2-way SLI Ready
Key Features
- dB Inverter
- NVIDIA SLI Ready
- OpenCL Support
- CUDA Cores: 1024
- Base Clock: 1216 MHz
- Boost Clock: 1279 MHz
- 2-way SLI Ready
Key Features
- NVIDIA SLI Ready
- OpenCL Support
![](https://www.evga.com/articles/00895/images/Software_PX16.jpg)
Key Features
- Temperature Target Control
- Pixel Clock Overclocking
![](https://www.evga.com/articles/00895/images/Software_OCX.jpg)
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 960 vitals. Learn more and download it here.
Key Features
- CPU Burn In Module
- Built-in log functionality
