Engineered for the Enthusiast
The EVGA X99 lineup has arrived. EVGA has rebuilt its motherboard lineup for the next generation Intel® platform, offering a stunning set of features and overclocking support. These motherboards also feature EVGA's new GUI BIOS that focuses on the best overclocking support, functionality, and are straight and to the point, the way a modern BIOS should be.
X99 Platform
Intel® X99 Platform Unlocks Incredible Performance
Intel® X99 Chipset
- Supports up to 16 CPU threads (8-core)
- First desktop platform to support DDR4 memory
- Up to 40 PCI-E 3.0 lanes
- Native SATA 6.0Gb/s & USB 3.0
- Up to 20MB CPU Cache on 8 Core CPU
Intel® Core™ i7-5960X vs. Intel® Core™ i7 4960X
- Game Physics and AI up to 14% FASTER (3DMark Fire Strike Physics Extreme)
- 4K Video Editing up to 20% FASTER (Adobe Premiere Pro CC)
- 3D Rendering up to 32% FASTER (CINEBENCH 15 X)
Intel® Core™ i7-5960X vs. Intel® Core™ i7 4790K
- Multithreaded Performance up to 79% FASTER (SPECint*_rate_base2006)
- 4k to 1080p Transcoding up to 69% FASTER (Handbrake)
EVGA X99 Classified Motherboard
Part Number: 151-HE-E999-KR
The EVGA X99 Classified was engineered from the ground up to be the best overclocking motherboard on the planet. It all starts with power. Dual 8 PIN CPU power inputs provide up to 600W of dedicated power for the CPU, along with a highly efficient 10-phase Digital VRM providing the cleanest power to the CPU possible, fed through a CPU socket that has 1.5X the amount of gold content. A total of 8 DIMM slots support up to 128GB of DDR4 memory, and a 4 layer memory T-routing design allows for extreme memory speeds such as 3200MHz+* (OC). The PCI-E layout is optimized for improved lane distribution and better performance, and with native support for NVIDIA 4-Way SLI, this is the ultimate platform for the enthusiast.
Specifications
- Chipset – Intel® X99 Express
- SLI – Up to 4-Way SLI
- SATA – 10 Native SATA 6.0Gb/s Ports
- USB – 6 Native USB 3.0 / 8 USB 2.0
- Memory – 8 DIMM Quad-Channel DDR4 3200MHz+* (OC) (Up to 128GB)
- Capacitors – 100% Solid State
- Form Factor – EATX
- Ethernet – 2x Intel® Gigabit NIC
- Audio – Creative Sound Core3D Quad-Core Audio Processor
- M.2 Socket Slot E and Slot M
- PCB – 8 Layers
Features
- Highly Efficient 10-phase Digital VRM
- Onboard Power, Reset and Clear CMOS
- PCI-E Disable Switches
- EVGA E-LEET X Tuning Utility
- Triple BIOS Support
- Onboard CPU Temp Monitor
- 150% Increased Gold Content
- EZ Voltage Read Points
- 8+8 PIN CPU Power Input – Dedicated 600W
External I/O
- 6x USB 2.0
- 4x USB 3.0
- 2x Gigabyte LAN
- Creative Sound Core3D Quad-Core Audio Processor
Internal I/O
- 1x USB 2.0 Header (2 Ports)
- 1x USB 3.0 Header (2 Ports)
- 10x SATA3/6G Ports
Gallery
EVGA X99 FTW Motherboard
Part Number: 150-HE-E997-KR
The EVGA X99 FTW was engineered from the ground up to win. A highly efficient 8-phase Digital VRM providing the cleanest power to the CPU possible, fed through a CPU socket that has 1.5X the amount of gold content. A total of 8 DIMM slots support up to 128GB of DDR4 memory, and a 4 layer memory T-routing design allows for extreme memory speeds such as 3200MHz+* (OC). The PCI-E layout is optimized for improved lane distribution and better performance, and with native support for NVIDIA 4-Way SLI, this is the ultimate platform for the performance user.
Specifications
- Audio – 8 Channel High Definition Audio + Optical
- PCB – 8 Layers
Features
- Highly Efficient 8-phase Digital VRM
- Dual BIOS Support
External I/O
- 6x USB 2.0
- 4x USB 3.0
- 2x Gigabyte LAN
- 8 Channel Audio + Optical
Internal I/O
Gallery
EVGA X99 Micro Motherboard
Part Number: 131-HE-E995-KR
The EVGA X99 Micro was engineered to pack a punch. A highly efficient 6-phase Digital VRM providing the cleanest power to the CPU possible. A total of 4 DIMM slots support up to 64GB of DDR4 memory, and a 4 layer memory design allows for extreme memory speeds such as 3200MHz+* (OC). The PCI-E layout is optimized for improved lane distribution and better performance, and with native support for NVIDIA 3-Way SLI, this is the ultimate platform for the performance user.
Specifications
- SLI – Up to 3-Way SLI
- SATA – 6 Native SATA 6.0Gb/s Ports
- Memory – 4 DIMM Quad-Channel DDR4 3200MHz+* (OC) (Up to 64GB)
- Form Factor – mATX
- Ethernet – Intel® Gigabit NIC
- M.2 Socket Slot E
- PCB – 8 Layers
Features
- Highly Efficient 6-phase Digital VRM
External I/O
- 6x USB 2.0
- 4x USB 3.0
- 1x Gigabyte LAN
Internal I/O
- 6x SATA3/6G Ports
Gallery
Academy
†Available on Classified and FTW
Triple BIOS Support
‡Dual BIOS on FTW
Right Angled 24 PIN
Includes M.2 Support
†Available on Classified and Micro
†Available on all models
Dual 8 PIN CPU Power
10 Phase PWM
8 Layer PCB
Higher Gold Content
†Classified and FTW have 150% gold content of the standard
* 2800MHz and 3200MHz modules are officially supported in latest BIOS update.
