0Introducing The e-GeForce4 MX
The e-GeForce4 MX is based on nVIDIA's new GeForce4 MX GPU which is the newest generation follow-on the their highly successful GeForce2 MX line of chipsets. The GeForce4 MX GPU is a cost-effective, high-performance integrated GPU, and is the only mainstream GPU to integrate the most comprehensive set of feature on a single chip.
As with previous versions of the MX line, the e-GeForce4 MX will come in a variety of configurations that will allow it to be useful in the widest possible number of system applications. Initially versions of the e-GeForce4 MX 440 and e-GeForce4 MX 420 will be available, followed on with other configurations in the coming months.
The e-GeForce4 MX line lists an impressive feature set:
Feature
e-GeForce4 MX 440
e-GeForce4 MX 420
Graphics Processor:
NVIDIA GeForce4 MX 440
NVIDIA GeForce4 MX 420
Graphics Core:
256-bit
256-bit
Core Clock Speed:
270 MHz
250 MHz
Memory Clock Speed:
400 MHz DDR
166 MHz SDR
Memory Bandwidth:
6.4 GB/sec.
2.7 GB/sec.
Memory Type:
64 MB DDR
64 MB SDR
Fill Rate (texels/sec.)
1.1 billion
1 billion
Triangles/sec.
34 million
31 million
Bus Type:
AGP 2X/4X
RAMDAC:
350 MHz
VGA Output:
Extended display resolution up to 2048x1536 at 75 Hz
TV-Out:
Extended display resolution up to 1024x768 S-Video
Supported APIs:
OpenGL 1.3 and lower, DirectX 8.1 and lower
Operating System:
Windows XP/2000/ME/98/NT
Key Features
nView™ - display technology provides the ultimate multiple display flexibility and user control.
NVIDIA Lightspeed Memory Architecture™ II -with 128-bit DDR radically improves memory efficiency.
NVIDIA Accuview™ Antialiasing -delivers high resolution, high frame rate, full scene antialiasing
NVIDIA Video Processing Engine™ -Enable the highest-quality, full-frame rate, full screen DVD without requiring a high performance CPU.
  • Integrated TV encoder (supporting 1024x768 resolution)
  • 2 dual-rendering pipelines
  • DirectX® and S3TC® texture compression
  • 4 texels per clock cycle
  • 32-bit color with 32-bit Z/stencil buffer
  • Cube environment mapping
  • 64MB high-speed 128-bit DDR memory
  • High-performance 2D rendering engine
  • AGP 4X with Fast Writes
  • NVIDIA Shading Rasterizer
  • AGP 4X/2X and AGP Texturing Support
  • Integrated hardware transform engine
  • Integrated hardware lighting engine
  • High-quality DVD playback
  • True, reflective bump mapping
  • Multibuffering (double, triple, quad) for smooth animation and video playback
  • Microsoft DirectX optimizations and support
  • AMD Processor optimizations and support
  • Intel Processor optimizations and support
nView Display Technology
The nView Multi-Display option allows a wide range of features that include connections between different output devices ranging from a standard analog computer monitor, digital flat panel to a television set. Improving upon the TwinView feature includes customizable desktops and display options to maximize the usability of more than one monitor.
Options listed are possible with nView Technology - however your video card will be limited based on the video outputs that it posesses.
Ultimate control - intuitive user interface
  • Easiest set-up
  • Application Management
  • Multi Desktop Support
  • Window Management
  • Window Effects
  • Custom User Profiles
NVIDIA Lightspeed Memory Architecture II
Constant challenges with 3D intensive applications is the limitations in memory bandwidth. The second generation of the Lightspeed Memory Architecture of its GeForce3 predecessor improves upon many of the revolutionary data retrieval techniques through the memory pipeline. The result is the transfer of data for vertices and pixels at blistering speeds.
  • MX Crossbar Memory Controller
  • Quad Cache
  • Lossless Z Compression
  • Optimized Z-Occlusion Culling
  • Memory Auto Pre-Charge
  • Fast Z-Clear
NVIDIA Accuview Antialiasing
In the past, it was difficult to implement a technique to smooth out the edges of an image without significantly hitting the system with a degrade in performance. Accuview antialiasing allows for applying a smoother transition between the edges of a pixel at different sampling levels without affecting a severe slow down in the frame rate.
  • Full Screen Antialiasing (FSAA) of 2X, 4X, Quincunx, and new 4XS mode.
  • Removal of "jaggies" to improve image quality and realism
  • Quincunx at FSAA 2X speeds
  • Run quality FSAA without performance degrades
NVIDIA Video Processing Engine (VPE)
To round out the complete entertainment package that is the GeForce4 MX is the integrated hardware decoding that improves upon the efficiency and system overhead of DVD decoding in conjunction with a software renderer. With the advent of high definition displays becoming more popular, the GeForce4 MX has built in compatibility to display at 1080i modes.
  • Hardware Assisted DVD (MPEG2) Decoding
  • Simple display scaling and filtering
  • Hardware color enhancements to improve playback quality
  • Improved PVR efficiency and support
  • HDTV setup compatible
Next Article
Article Viewed: times since
