EVGA Hydrocopper 16 with Co-op Technology.
EVGA Introduces the Hydro Copper 16 Waterblock with Co-op Technology!
Hydro Copper Waterblocks cooling efficiency go up as heat continues to go down with the introduction of EVGA's Co-op Technology.
Currently featured on the GTX 280 / 260 Hydro Copper 16 Waterblock, Co-op Technology offers cooling for the backside of the GTX 280 / 260. Made of aluminum with integrated fins and heat-pipes, now even the hot backside gets attention with full heat dissipation. Innovative Co-op Technology interlocks with the Hydro Copper 16 Waterblock so that heat from both the topside and backside of the GTX 280 / 260 is easily dissipated. Increased cooling for your increased speeds: another intelligent innovation from EVGA.
EVGA Introduces the Hydro Copper 16 Waterblock with Co-op Technology! EVGA Introduces the Hydro Copper 16 Waterblock with Co-op Technology! EVGA Introduces the Hydro Copper 16 Waterblock with Co-op Technology!
Features:
  • Dissipates heat from the backside of the memory and GPU
  • Lowers temperatures and allows for highest clock speeds possible
  • Currently, exclusive only to the EVGA Hydro Copper 16 Waterblock
  • Multiple patents pending, exclusive only to EVGA
200-CU-HC16-B1
EVGA GTX 280 Hydro Copper 16 waterblock
Part Number 200-CU-HC16-B1
Fittings Supports 3/8'' & 1/2'' Systems
Fitting Config. Up to 4
Material Copper
GeForce is a registered trademark of NVIDIA Corporation in the United States and other countries.
Article Viewed: 18870 times since 6/25/2008
