EVGA Hydro Copper 18 9800GX2 Block
EVGA 9800GX2 Hydro Copper 18, now available with card.
The EVGA 9800GX2 Hydro Copper 18 block was a hit, now is your chance to own this block along with the EVGA 9800GX2 for an amazing deal.
The EVGA 9800GX2 Hydro Copper 18 waterblock was specifically designed to maximize heat transfer and give you the lowest operating temps possible. High flow designed internals and barbs minimize flow restriction, giving you the most ultimate in performance.
This card is compatible with all 1/2'' and 3/8'' cooling systems, barbs are included and there is an extremely limited QTY so do not miss out on this opportunity!
  • Fastest graphics solution on planet earth.
  • EVGA Exclusive pattern design maximizes surface area and reduces temps.
  • 100% Copper design
  • 100% testing on every block
  • Cool's GPU, VREG, I/O Chip and Memory
  • Includes high quality 1/2'' and 3/8'' High Flow fittings
  • Includes lifetime warranty
  • SLI Compatible
  • Flexible barb design allows 4 different fitting configurations, giving maximum flexibility for water cooling placement accessories
Included:
  • EVGA 9800GX2 Graphics Card
  • EVGA Hydro Copper 18 9800GX2 Copper Water Block
  • 2x High quality 1/2'' and 3/8'' High Flow fittings
  • 2x High quality Stop Fitting
  • 2x 1/2'' Stainless Steel Hose Clamps
  • 2x 3/8'' Stainless Steel Hose Clamps
Article Viewed: 36639 times since 5/30/2008 3:28:23 PM
