3 WAY SLI
3 WAY SLI
SLI3 - The Power of Three.
Unmatched Graphics Performance
Introducing the latest in NVIDIA SLI technology; 3-Way SLI. With three EVGA 8800 Ultras along with the EVGA 680i motherboard, you can have the absolute fastest gaming platform on the planet.
Performance:
  • Enables up to 2.8x performance increase over a single GPU
  • Play the latest next generation applications in mind blowing framerates while running at extreme HD resolutions of 2560x1600
  • Delivers richer and more immersive game environments by powering the latest effects in DirectX 10
Revolutionary Technology
  • 384 combined stream processors
  • 110+ Gigatexel per second texture fill rate
  • Absolute fastest gaming solution available
see 3 Way SLI
GO 3 Way SLI
The following products enable 3-Way SLI:
  • 3x EVGA 8800GTX or Ultra
  • 1x EVGA 680i Motherboard
  • 1x 3-Way SLI Bridge (purchase here)
132-CK-NF79-A1
nForce 790i Ultra SLI
Part Number 132-CK-NF79-A1
CPU Support Intel Socket 775
Chipset NVIDIA nForce 790i Ultra SLI Chipset
Memory Support DDR3 1066/1333/1600/2000 MHz
FSB Speed Supports 800/1066/1333/1600 Mhz
SATA Header 7
SATA Type 300MB/sec
USB Ports 10
PCIE Slot 3 x PCIe x16, 2 x PCIe x1, 2 x PCI
upon registration
122-CK-NF68-A1
nForce 680i SLI
Part Number 122-CK-NF68-A1
Chipset NVIDIA nForce 680i SLI Chipset
Memory Support DDR2 533/667/800/1200MHz SLI-Ready memory
FSB Speed Supports 1066/1333 Mhz
SATA Header 6
SATA Type 300MB/sec
USB Ports 10
PCIE Slot 2 x PCIe x16, 1 x PCIe Graphics expansion slot, 2 x PCIe x1, 2 x PCI
upon registration
Article Viewed: 109333 times since 12/13/2007 7:00:00 AM
