e-Geforce 8800 SSC Edition
The EVGA 8800 SSC Edition
Power is Everything with SSC
Take an EVGA 8800 GTS with 640MB of DDR3 Memory, crank up the performance, what do you get? You get the EVGA 8800 GTS SSC.
96+ Shader Units clocked at an incredible 1.35GHz make this card a must have for any high-resolution gamer. Remember, when you think EVGA SSC, think EVGA Performance.
Performance:
  • 100% testing ensures the highest level of performance and stability possible.
  • DDR3 Memory clocked at an amazing 1.8GHz giving you 64GB/sec of memory bandwidth.*
  • GPU clockrate at a true 576MHz.
  • 96+ Shader Units at a remarkable 1.35GHz.
The EVGA 8800 GTS SSC Power
Features:
  • Full DX10 support Full Direct X 10 and Shader Model 4.0 support delivers uparalleled levels of graphics realism and film- quality effects.
  • Unified Shader Architecture - Combines vertex, pixel and geometry shaders for an overall more efficient architecture.
  • NVIDIA Quantum Effects Enables a new level of physics effects to be rendered and simulated on the GPU.
  • 128-bit HDR with FSAA Realistic High Dynamic Range lighting, now with support for anti-aliasing!
  • Built for Microsoft Windows Vista Fourth generation GPU architecture gives Windows Vista users the best possible experience with Windows Aero 3D user interface.
Available at:
All these new technologies found in the e-GeForce 8 series GPU processors allow the PC Platforms to experience high-resolution, high performance gaming, and stellar high-definition visuals.
*8800 GTS model
Article Viewed: 124519 times since 10/29/2007 7:00:00 AM
