e-Geforce 8600 512 MB
The EVGA 8600 512 MB
EVGA 8600 GTS� now loaded with 512MB DDR3!
The EVGA 8600 GTS, is now packed with half a gig of DDR3 memory, available in both standard and Superclocked varieties, this ensures you get the right card for any environment.
Both models equipped with 512MB of DDR3 at a screaming 2GHz clockrate give you the performance advantage you need, when you need it. And with a GPU clockrate at a �true� 706MHz, the 8600GTS Superclocked 512MB card is a must have for any gamer.
In addition to the breakneck performance, these cards come with the complete 8 series features, including DirectX10/Shader Model 4.0 and full support for HDR + Full Screen Anti-Aliasing.
Performance:
  • 100% testing ensures the highest level of performance and stability possible.
  • 512MB of DDR3 at 2GHz, 32GB/sec of memory bandwidth.
  • Fill Rate of up to 11.3 gigapixels per second.*.
  • GPU clockrate at a �true� 706MHz*.
  • Stream Processor clock at an incredible 1.51GHz*.
Features:
  • Full DX10 support � Full Direct X 10 and Shader Model 4.0 support delivers uparalleled levels of graphics realism and film- quality effects.
  • Unified Shader Architecture - Combines vertex, pixel and geometry shaders for an overall more efficient architecture.
  • NVIDIA Quantum Effects � Enables a new level of physics effects to be rendered and simulated on the GPU.
  • 128-bit HDR with FSAA � Realistic High Dynamic Range lighting, now with support for anti-aliasing!
  • Built for Microsoft Windows Vista � Fourth generation GPU architecture gives Windows Vista users the best possible experience with Windows Aero 3D user interface.
Available at:
Buy the EVGA 8600 512 MB here.
All these new technologies found in the e-GeForce 8 series GPU processors allow the PC Platforms to experience high-resolution, high performance gaming, and stellar high-definition visuals.
*Superclocked model
Article Viewed: 69598 times since 8/1/2007 4:49:19 PM
