EVGA NEWS FLASH
Important message regarding memory and the EVGA 680i motherboard
NVIDIA has investigated end user reports of high performance DIMM failures on the NVIDIA nForce 680i SLI-based platforms. During this process we have been in close contact with DIMM manufacturers and the DRAM manufacturers they rely on to understand the failure scenario. By working with our community, we believe that the observed failure is a breakdown of the silicon in the DRAM caused by the prolonged application of 2.4V on the voltage rails of the DIMMs.
NVIDIAs own internal testing has observed this failure on multiple motherboards using different chipsets (both NVIDIA and non-NVIDIA chipsets). This issue is not directly related to motherboards using the NVIDIA nForce 680i SLI MCP or other chipsets.
If you are using this type of memory and are experiencing this issue, NVIDIA recommends contacting your memory manufacturer or system manufacturer for additional information and warranty information.
Article Viewed: 46784 times since 3/29/2007
