Introducing the e-GeForce 8800 GTS
Introducing the
e-GeForce 8800 GTS
Redefine reality with the EVGA SLI™-Ready GeForce® 8800 graphics processing unit. The world's first DX10 GPUs feature a unified architecture and unprecedented levels of graphics performance and realism.
  • NVIDIA® unified architecture:
    Fully unified shader core dynamically allocates processing power to geometry, vertex, physics, or pixel shading operations, delivering up to 2x the gaming performance of prior generation GPUs.
  • GigaThread™ Technology:
    Massively multi-threaded architecture supports thousands of independent, simultaneous threads, providing extreme processing efficiency in advanced, next generation shader programs.
  • Full Microsoft® DirectX® 10 Support:
    World's first DirectX 10 GPU with full Shader Model 4.0 support delivers unparalleled levels of graphics realism and film-quality effects.
  • NVIDIA® SLI™ Technology:
    Delivers up to 2x the performance of a single graphics card configuration for unequaled gaming experiences by allowing two cards to run in parallel.
  • Dual Dual-link DVI Support:
    Able to drive the industry's largest and highest resolution flat-panel displays up to 2560x1600.
  • Built for Microsoft® Windows Vista™:
    NVIDIA's fourth-generation GPU architecture built for Windows Vista gives users the best possible experience with the Windows Aero 3D graphical user interface.
  • NVIDIA® nView® Multi-Display Technology: Advanced technology provides the ultimate in viewing flexibility and control for multiple monitors.
   nVidia e-GeForce 8800 GTS
Limited Lifetime Warranty - 24/7 Customer Support - 90 Days Step-Up™ Program
Lumenex™ Engine
  • Delivers stunning image quality and floating point accuracy at ultra-fast frame rates:
    • 16x Anti-aliasing: Lightning fast, high-quality anti-aliasing at up to 16x sample rates eliminates jagged edges.
    • 128-bit floating point High Dynamic-Range (HDR): Twice the precision of prior generations for incredibly realistic lighting effectsnow with support for anti-aliasing!
NVIDIA® Quantum Effects™ Technology
  • Advanced shader processors architected for physics computation enable a new level of physics effects to be simulated and rendered on the GPUall while freeing the CPU to run the game engine and AI.
Built for Windows Vista™ — the next-generation operating system (OS) from Microsoft®
  • Fourth-generation GPU architecture built for Windows Vista™
  • Delivers best possible experience when running the Windows Vista™ 3D graphical user interface
  • NVIDIA® PureVideo™ technology delivers high-quality VMR pipeline for best-in-class video for Windows Vista™
Article Viewed: 22305 times since 11/8/2006
