Are Performance Clocked 7800 GTX Cards Just Wishful Thinking?
Is a stable 7800 GTX with core speeds of 490+ and memory clock speeds of 1300+ just wishful thinking?
It certainly is if you intend to run the card with the reference cooling solution. With the stock cooler, stability at such high speeds is a hit or miss proposition at best - and even if it does work, you're still risking long term damage to the card.
With EVGA's patented ACS cooling technology mated to one of our new 7800 GTX KO Edition cards, you can lower your core GPU temperatures by about 5C to 7C, and your memory temperatures by about 8C to 10C - creating an environment that is much better suited to high performance clocking.
So, with EVGA's ACS, while running at 490+ core and 1300+ memory, your system is safe and stable. It's not just wishful thinking - it's as real as the technology that makes it possible. And, with our Limited Lifetime Warranty, you have absolutely nothing to lose.
It's not wishful thinking, its EVGA.
