The revolutionary new NVIDIA® TurboCache™ technology utilizes the additional bandwidth of PCI Express to reach higher levels of graphics performance than traditional video memory solutions. TurboCache shares the capacity and bandwidth of dedicated video memory and dynamically available system memory for turbocharged performance and larger total graphics memory.
For the first time ever, all of the powerful features found in NVIDIA's flagship GPU will be available at the entry level.
With the NVIDIA 6200 with TurboCache technology, now everyone can enjoy the features and perfomance that make NVIDIA's 6 series GPUs the best in the world!
Experience improved system performance, stunning high-quality video playback, and the latest 3D gaming technology with an entry level GPU - somthing not possible with integrated graphics or from any other entry level graphics card.
How Does It Work?
By using the power and the flexibility of the PCI-Express bus, NVIDIA has developed a means of dynamically accessing the computer's system memory in order to allocate it for use as frame buffer memory for the graphics card. This is not the same as other memory sharing techniques such as the shared memory that integrated graphics rely on, or even AGP texture memory. NVIDIA's TurboCache technology allows the graphics card to dynamically allocate as much or as little memory as is needed for any given video operation; and because each card is equipped with real memory local to the video card, many day to day operations such as web browsing, emails, watching movies or viewing photos, etc. can be performed without the need of any system memory at all. But when the task turns to gaming or heavy 3D environments, the 6200 TurboCache can access the system memory it needs at speeds as fast as 13.6 GB/sec - faster than the local memory found on many entry level cards.
Graphics to Drench Your Senses
Turbocharged system performance to play all the hottest games and applications
  • Dedicated graphics processing unit (GPU) offloads the CPU and increases overall system performance
  • Patented NVIDIA® TurboCache™ technololgy dynamically allocates memory for maximum system performance
  • Support for the latest bus standard - PCI Express® - speeds up data transfer for improved system performance
Advanced 3D graphics and video features of the latest generation GPUs
  • Experience stuning, high-quality video playback and superb picture clarity on your PC with NVIDIA® PureVideo™ technology
  • Experience the latest gaming effects without compromising performance with Microsoft® DirectX® 9.0 Shader Model 3.0 support
The compatibility, stability, and reliability you expect from NVIDIA, the worldwide leader in graphics and media processors
  • Worry-free compatibility for an easy "install-and-play" experience
  • Rock-solid stability and reliability with the renowned NVIDIA® ForceWare™ Unified Driver Architecture (UDA)
  Key Features of the 6200 with TurboCache Technology
  • 350 MHz Core Clock
  • Superscalar GPU architecture
  • NVIDIA® TurboCache™ technology
  • NVIDIA® CineFX™ 3.0 engine
  • High-speed DDR memory interface
  • NVIDIA® UltraShadow™ II technology
  • NVIDIA® PureVideo™ technology
  • NVIDIA® ForceWare™ Unified Driver Architecture (UDA)
  • NVIDIA® nView® multi-display technology
  • NVIDIA® Digital Vibrance Control™ 3.0 technology
  • PCI Express support
  • Microsoft® DirectX® 9.0 shader Model 3.0 support
  • OpenGL® 1.5 support
Estimated Shipping Date:
Early January 2005
