Revolutionary
Superscalar Architecture
Delivers
up to 8x the shading power of previous generation products
for screaming gaming performance. |
CineFX
3.0 Engine
Powers
the next generation of cinematic realism. Full support
for Microsoft® DirectX® 9.0 Shader Model 3.0
enables stunning and complex special effects. Next-generation
shader architecture delivers faster and smoother gameplay. |
On-Chip
Video Processor
Delivers
unmatched video performance, features, and quality. |
UltraShadow
II Technology
Enhances
the performance of bleeding-edge games, like id Software’s
Doom III, that feature complex scenes with multiple
light sources and objects. 2nd-generation technology
delivers more than 4x the shadow processing power over
the previous generation. |
64-Bit
Texture Filtering and Blending
Based
on the OpenEXR technology from Industrial Light &
Magic, NVIDIA’s 64-bit texture implementation
sets new standards for image clarity and quality through
floating point capabilities in shading, filtering, texturing,
and blending. |
Intellisample
3.0 Technology
The
industry’s fastest antialiasing delivers ultra-realistic
visuals, with no jagged edges, at lightning-fast speeds.
Visual quality is taken to new heights through a new
rotated grid sampling pattern. |
Unified
Driver Architecture (UDA)
Part of the NVIDIA Forceware unified software environment
(USE). The NVIDIA UDA guarantees forward and backward
compatibility with software drivers. Simplifies upgrading
to a new NVIDIA product because all NVIDIA products
work with the same driver software. |
nView
Multi-Display Technology
The
nView hardware and software technology combination delivers
maximum flexibility for multi-display options, and provides
unprecedented end-user control of the desktop experience.
NVIDIA GPUs are enabled to support multi-displays, but
graphics cards vary. Please verify multi-display support
in the graphics card before purchasing. |
Digital
Vibrance Control 3.0
Allows
the user to adjust color controls digitally to compensate
for the lighting conditions of their workspace, in order
to achieve accurate, bright colors in all conditions. |
PCI
Express Support
PCI
Express is a new Intel bus architecture that doubles
the bandwidth of the AGP 8X bus, delivering over 4 GB
per second in both upstream and downstream data transfers.
Only supported in some NVIDIA GPUs. Please check product
details for bus information. |
Microsoft®
DirectX® 9.0 Optimizations and Support
Ensures
the best performance and application compatibility for
all DirectX 9 applications.
Full-Speed
32-Bit Color Precision
Delivers
increased image quality with no performance compromise. |
Full
MPEG Support
Delivers
a stunning video experience through encoding and decoding
of analog and digital content. |
Advanced
Adaptive De-Interlacing
Smoothes video and DVD playback on progressive displays. |
Video
Scaling and Filtering
High-quality scaling and filtering technology improves
video playback quality at any window size, including full-screen
HDTV resolutions. |
Integrated
TV Encoder
Provides best-of-class TV-out functionality for resolutions
up to 1024x768. |
OpenGL®
1.5 Optimizations and Support
Ensures the best performance and application compatibility
for all OpenGL applications. |
Dual
400MHz RAMDACs
Blazing-fast RAMDACs support dual QXGA displays with ultra-high,
ergonomic refresh rates–up to 2048x1536@85Hz. |
Dual
Single-Link DVI Support
Able to drive the industry’s largest and highest
resolution flat-panel displays. |
Microsoft®
DirectX® 9.0 Shader Model 3.0 Support
Ensures top-notch compatibility and performance for all
DirectX 9 applications, including Shader Model 3.0 titles. |
Integrated
HDTV Encoder (Optional)
Provides world-class HDTV-out functionality up to and
including 1920x1080i resolutions. |
