![](/articles/images/184.jpg)
e-GeForce 6800 Ultra, 256MB Part Number: 256-A8-N345-AX
The groundbreaking new NVIDIA GeForce 6800 graphics processing units (GPUs) and their revolutionary technologies power worlds where reality and fantasy meet; worlds in which new standards are set for visual realism and quality, performance, and video functionality. The GeForce 6800 GPUs deliver powerful, elegant graphics to drench your senses, immersing you in unparalleled worlds of visual effects for the ultimate PC experience.
![](/articles/images/184-a.gif)
NOW AVAILABLE!
SPECS AT A GLANCE |
Core Clock Speed |
Dynamic* |
Memory Clock Speed |
550 MHz |
Memory Bandwidth |
35.2 GB/sec |
Vertices per Second |
600 Million |
Memory Data Rate |
1100 MHz |
Pixels per Clock (peak) |
16 |
Textures per Pixel** |
16 |
RAMDACs |
400 MHz |
*With Dynamic Clock Speeds, the video card will automatically detect the maximum safe speed to operate at, based on your systems capabilities. This speed will never be lower than 400 MHz. **Maximum in a single redering pass |
Complete Features and Highlights:
- Superscalar 16-Pipe GPU Architecture
Delivers 8x the shading power of previous generation products for screaming gaming performance.
- CineFX 3.0 Engine
Powers the next generation of cinematic realism. Full support for Microsoft DirectX 9.0 Shader Model 3.0 enables stunning and complex special effects. Next-generation shader architecture delivers faster and smoother gameplay.
- The Industry's First On-Chip Video Processor
Delivers unmatched video performance and features.
- UltraShadow II Technology
Enhances the performance of bleeding-edge games, like id Softwares Doom III, that feature complex scenes with multiple light sources and objects. 2nd-generation technology delivers more than 4x the shadow processing power over the previous generation.
- 64-Bit Texture Filtering and Blending
Based on the OpenEXR technology from Industrial Light & Magic, NVIDIAs 64-bit texture implementation sets new standards for image clarity and quality through floating point capabilities in shading, filtering, texturing, and blending.
- Intellisample 3.0 Technology
The industrys fastest antialiasing delivers ultra-realistic visuals, with no jagged edges, at lightning-fast speeds. Visual quality is taken to new heights through a new rotated grid sampling pattern.
- Unified Driver Architecture (UDA)
Part of the NVIDIA Forceware unified software environment (USE). The NVIDIA UDA guarantees forward and backward compatibility with software drivers. Simplifies upgrading to a new NVIDIA product because all NVIDIA products work with the same driver software.
- nView Multi-Display Technology
The nView hardware and software technology combination delivers maximum flexibility for multi-display options, and provides unprecedented end-user control of the desktop experience.
- Digital Vibrance Control 3.0
Allows the user to adjust color controls digitally to compensate for the lighting conditions of their workspace, in order to achieve accurate, bright colors in all conditions.
- High-Speed GDDR3 Memory Interface
Support for the worlds fastest GDDR3 memory delivers fluid frame rates for even the most advanced games and applications.
- 256-Bit Memory Interface with Advanced Memory Control
Delivers more memory bandwidth and efficiency to power the latest games and applications at blazing speeds.
- 128-Bit Studio-Precision Computation
128-bit studio-precision computation through the entire pipeline prevents image defects due to low precision and ensures the best image quality for even the most demanding applications.
- Full-Speed 32-Bit Color Precision
Delivers increased image quality with no performance compromise.
