256-BIT
ADVANCED MEMORY INTERFACE
Wider memory data path with next generation controller technology
for superior performance throughput.
NVIDIA
CINEFX 2.0 ENGINE
• Advanced pixel shaders deliver 2x the floating-point
shader pixel performance of previous generations
• Support for Microsoft® DirectX® 9.0 (DX9)
pixel shader 2.0+
• Support for DX9 vertex shader 2.0+
• Long pixel programs up to 1,024 instructions
• Long vertex programs up to 256 static instructions
with up to 65,536 instructions executed
• Dynamic, conditional execution and flow control
• Architected for Cg and Microsoft HLSL for maximum
compatability for next-generation content
• 128-bit, studio-quality, floating-point precision
computation through the entire rendering pipeline
• Native hardware support for 32 bpp, 64 bpp, and 128
bpp rendering modes
• Up to 12 pixel shader operations per clock
• Up to 16 texture shader operations per clock
• Support for sRGB texture format for gamma textures
• DirectX and S3TC texture compression
• Optimized for 32-, 24-, 16-, 15-, and 8-bpp modes
• True-color, 64x64 hardware cursor alpha
• Multibuffering (double, triple or quad) for smooth
animation and video playback.
INTELLISAMPLE
HCT TECHNOLOGY
• Increased visual quality at higher resolutions
through advances in compression, anistropic filtering, and antialiasing
technology
• Blistering-fast antialiasing and compression performance
• Support for advanced lossless compression algorithms
for both color, texture, and z data at even higher resoltuions and
frame rates
• Fast x-clear
ULTRASHADOW
TECHNOLOGY
Accelerates shadow volumes for next-generation games
• Accurately maintains shadows while discarding non-useful
information
ADVANCED
DISPLAY PIPELINE
• Integrated NTSC/PAL TV encoder supporting
resolutions up to 1024x768 without the need for panning with built-in
Macrovision copy protection
• DVD and HDTV-ready MPEG-2 decoding up to 1920x1080i
resoltions
• Dual, integrated 400 MHz RAMDACs for display resolutions
up to and including 2048x1536@85 Hz
• Dual DVO ports for interfacing to txternal TMDS transmitters
• Internal TV support
• VIP 1.1 interface support for Video In function
• Microsoft Video Mixing Renderer (VMR) support for
multiple video windows with full video quality and features in each
window
NVIDIA
DIGITAL VIBRANCE CONTROL 3.0
• DVC image sharpening controls
• DVC color controls
ADVANCED
TECHNOLOGY
• AGP 8X including Fast-Writes and sideband
addressing
• 0.13-micron precess technology for higher levels of
integration and higher operating clock speeds
• Advanced thermal management and thermal monitoring
• 40 mm x 40 mm, BGA 1309 flip-chip package
OPERATING
SYSTEM SUPPORT
• Microsoft Windows® XP
• Windows ME
• Windows 2000
• Windows 9x
API
SUPPORT
• Comprehensive Microsoft DirectX 9.0 (and
lower) support
• OpenGL 1.4 (and lower) support |
