![Header](https://images.evga.com/articles/01571/header.jpg?v=0.1)
EVGA GeForce RTX™ 3090 Ti K|NGP|N HYBRID
“The EVGA GeForce RTX™ 3090 Ti K|NGP|N is designed from top to bottom to be the ultimate and highest overclocking graphics card on the planet.”
– Jacob Freeman – Global Product Management Director
“The EVGA GeForce RTX™ 3090Ti K|NGP|N represents seven straight generations of overclocking engineering and performance domination.”
– Vince “K|NGP|N” Lucido
![power connector](https://images.evga.com/articles/01571/power.png)
“2x” 16-PIN Power Connector
A software-controlled Digital Power Solution is more precise and accurate, giving you ample power to push this card to the limit. 2x 16-Pin power connectors located on the right side of the PCB allow for easy cable management and MEGA power delivery.
14-Layer PCB
The backbone of the EVGA GeForce RTX 3090 Ti K|NGP|N is a 14-Layer PCB augmented by an exceptional power design with extreme overclocking in mind. With Integrated Smart Power Stages - each capable of supplying continuous current - the K|NGP|N has a powerful VRM matching or exceeding the best GeForce RTX™ 3090 Ti graphics cards available.
![PCB](https://images.evga.com/articles/01571/pcb.png)
![powerLink™ 52u](https://images.evga.com/articles/01571/powerLink.png)
EVGA PowerLink™ 52u
Exclusively-designed for the EVGA GeForce RTX 3090 Ti K|NGP|N Series, the EVGA PowerLink™ 52u provides the ultimate experience for cable management, better case airflow, improves power stability, and reduces ripple and noise. (Sold Separately)
FREE eLeash*
with EVGA GeForce RTX™ 3090 Ti K|NGP|N Series
With eLeash* Your Graphics Card is Always at the Right Position.
Click to learn more.
![eLeash*](https://images.evga.com/articles/01571/eLeash.png)
EVGA GeForce RTX™ 3090 Ti K|NGP|N HYBRID Features
A built-in, flip-up 176 x 48 pixels OLED display allows you to monitor your whole VGA status. This OLED is integrated into the PCB, meaning that no matter the graphics card orientation or the cooler being used, the display can be easily read. Monitor real-time voltages, temperatures, clocks and more.
![K|NGP|N](https://images.evga.com/articles/01571/kingpin.gif)
![OD](https://images.evga.com/articles/01571/OD.png)
“OLED supports up to 9 GIF animations – 6 default + 3 user created uploads”
Integrated headers for monitoring voltages in real time allowing you to push the EVGA GeForce RTX™ 3090 Ti K|NGP|N to new levels with precision levels of power and frequency. Three selectable onboard BIOS chips let you choose between Normal, OC or LN2 modes.
![processors](https://images.evga.com/articles/01571/processors02.png)
The EVGA GeForce RTX™ 3090 Ti K|NGP|N HYBRID is built with an Asetek 360 closed loop water cooling radiator using three of the latest EVGA ARGB fans. This card runs incredibly cool, giving you super-low temperatures to maximize your GPU Clock.
![processors](https://images.evga.com/articles/01571/processors03.png)
