Header
The EVGA GeForce RTX™ 3090 Ti is colossally powerful in every way imaginable, giving you a whole new tier of performance at 8K resolution. It's powered by the NVIDIA Ampere architecture, which doubles down on ray tracing and AI performance with enhanced RT Cores, Tensor Cores, and new streaming multiprocessors. Combined with the latest cooling solutions including Vapor Chamber heat plate, 3.5 slot cooling and full control with EVGA Precision X1 software, the EVGA GeForce RTX™ 3090 Ti FTW3 Series redefines the definition of ultimate performance.
Designed for the most demanding gamers, content creators and data scientists, the EVGA GeForce RTX™ 3090 Ti FTW3 Series features a record-breaking 10,752 CUDA cores, and boasts 78 RT-TFLOPs, 40 Shader-TFLOPs and 320 Tensor-TFLOPs of power. And it's packed with 24GB of the fastest 21Gbps GDDR6X memory, providing 1TB/s of memory bandwidth.
2nd generation
rt cores
2X THROUGHPUT
3RD GENERATION
TENSOR CORES
UP TO 2X THROUGHPUT
NEW
SM
2X FP32 THROUGHPUT
3090
Only On GeForce RTX
nv icon
The World's
Fastest GPUs
NVIDIA Ampere Architecture
nv icon
MOST REALISTIC &
IMMERSIVE GRAPHICS
2nd Gen Ray Tracing
nv icon
AI-ACCELERATED
PERFORMANCE
NVIDIA DLSS
nv icon
Lowest
System Latency
NVIDIA Reflex
nv icon
THE BEST EXPERIENCE
FOR EVERY GAME
Game Ready Drivers
nv icon
BUILT FOR
LIVE STREAMING
NVIDIA Encoder
nv icon
AI-ENHANCED
VOICE & VIDEO
NVIDIA Broadcast App
nv icon
FAST-TRACK
YOUR CREATIVITY
NVIDIA Studio
nv
8K HDR GAMING
Connect, play, capture, and watch in brilliant HDR at resolutions up to 8K with GeForce RTX™ 3090 or RTX™ 3090 Ti. Capture up to 8K HDR footage with the GeForce Experience™ ShadowPlay™ feature and play back smoothly with AV1 decode.
nv
GET FASTER PERFORMANCE WITH NVIDIA DLSS MAX FPS. MAX QUALITY. POWERED BY AI.
Get a performance boost with NVIDIA DLSS (Deep Learning Super Sampling). AI-specialized Tensor Cores on GeForce RTX™ GPUs give your games a speed boost with uncompromised image quality. This lets you crank up the settings and resolution for an even better visual experience.
nv
RAY TRACING
Ray tracing simulates how light behaves in the real world to produce the most realistic and immersive graphics for gamers and creators. GeForce RTX™ 30 Series has 2nd generation RT Cores for maximum ray tracing performance.
nv
UP YOUR CREATIVE GAME
Take your creative projects to a new level with GeForce RTX™ 30 Series GPUs. Experience AI-acceleration in top creative apps and enhance your workflows with the NVIDIA Studio platform of dedicated drivers and exclusive tools. Whether you're rendering complex 3D scenes, editing 8K video, or seamlessly connecting and collaborating with NVIDIA Omniverse™, GeForce RTX™ GPUs give you the performance to create your best.
nv
YOUR AI-POWERED HOME STUDIO
The NVIDIA Broadcast app transforms any room into a home studio—taking your live streams, voice chats and video conference calls to the next level with powerful AI effects like noise removal, virtual background, and more.
nv
CONNECT YOUR CREATIVE WORLDS TO A UNIVERSE OF POSSIBILITY
NVIDIA Omniverse™ is a 3D design collaboration platform within the NVIDIA Studio suite of tools for creators. Built to accelerate workflows, unite apps and assets to bring your ideas to life—fast.
FREE eLeash*
with EVGA GeForce RTX 3090 Ti FTW3 Series
With eLeash* Your Graphics Card is Always at the Right Position.
eLeash*
EVGA GeForce RTX 3090 Ti FTW3 Series Features
processors
A newly-designed heatsink with Vapor Chamber heat plate spreads heat in two dimensions. As the GPU gets hotter, liquid in the vapor chamber is vaporized and spreads throughout the chamber through micro-thin heatpipes to maximize cooling efficiency. As the GPU cools down, the vapor returns to a liquid state and the process starts again.
processors
Rigid Die Cast Backplate with Heatpipe not only secure your graphics card during operation and shipping, with building eLeash* notch to keep your EVGA GeForce RTX™ 3090 Ti FTW3 at the right position.
processors
Incredible performance demands incredible cooling. The EVGA GeForce RTX™ 3090 Ti FTW3 Series features a 27% larger heat dissipation area.
processors
The Hydrodynamic Bearing 2.0 (HDB) fan motor on the EVGA GeForce RTX™ 3090 Ti FTW3 Series feature an optimized 0dB mode under low loads and asynchronous fan operation. In addition, a special raised “E” pattern on fan blades reduce airflow noise under normal operation.
EVGA GeForce RTX 3090 Ti FTW3 Series Exploded View
    1
    2
    3
    4
    5
    6
    7
1
2
3
4
5
6
7
PX1
Products
EVGA GeForce RTX™ 3090 Ti K|NGP|N HYBRID GAMING
EVGA GeForce RTX™ 3090 Ti FTW3 HYBRID GAMING
FTW3 HYBRID GAMING
EVGA GeForce RTX™ 3090 Ti FTW3 ULTRA GAMING
FTW3 ULTRA GAMING
EVGA GeForce RTX™ 3090 Ti FTW3 GAMING
FTW3 GAMING
EVGA GeForce RTX™ 3090 Ti FTW3 BLACK GAMING
FTW3 BLACK GAMING
*Patent Pending
Discuss in Forums
