EVGA SuperNOVA P3
A New Generation of Platinum Power
EVGA SuperNOVA power supplies are well-known for their extreme efficiency, performance and reliability. EVGA’s dedication to performance has forged its newest higher-wattage power supply platform: the EVGA SuperNOVA P3 Series. With these new power supplies, EVGA took the best features of the award-winning P2 lineup and made them even better. The SuperNOVA P3’s smaller size, improved performance and a new Fluid Dynamic Bearing fan give you ultra-quiet performance with an increased lifespan.
A reduced size doesn't mean reduced performance with the EVGA SuperNOVA P3. At only 180mm long, this makes the P3 one of the smaller 80 Plus Platinum power supplies on the market today, while offering improved performance and features.
Better performance, quieter operation and a longer lifespan.
Next-generation systems deserve next-generation performance. The EVGA SuperNOVA P3 takes the already efficient P2 series and makes it even better with improved efficiency and lower ripple. These power supplies are over 92% efficient!
WHISPER QUIET
EVGA ECO mode means the power supply is completely silent during low to medium loads. This is one quiet power supply!
Use only the cables you need, reducing cable clutter and improving case airflow.
World Leading
World leading warranty and support for 10 years.
Products
Features
- 80 PLUS Platinum certified, with 92% (115VAC) / 94% (220VAC~240VAC) efficiency or higher under typical loads
- Full-bridge LLC Resonant Converter and DC-DC design leads to tight voltage regulation and low ripple & noise
- Fluid Dynamic Bearing Fan for ultra-quiet operation and increased lifespan.
Specs
- (OVP) Over Voltage Protection
- (OCP) Over Current Protection
- (SCP) Short Circuit Protection
- (UVP) Under Voltage Protection
- (OTP) Over Temperature Protection
- (OPP) Over Power Protection
AC Input | 100-240V~, 14-7A, 60/50Hz | ||||
MAX Output | 25A | 25A | 100A | 0.5A | 3A |
Combined | 125W | 1200W | 6W | 15W | |
Output Power | 1200W |
Features
Specs
AC Input | 100-240V~, 12-6A, 60/50Hz | ||||
MAX Output | 25A | 25A | 83.3A | 0.5A | 3A |
Combined | 125W | 1000W | 6W | 15W | |
Output Power | 1000W |
What power supply is right for you?
Check out EVGA power meter
