![Header](https://images.evga.com/articles/01505/header.jpg?v=0.1)
![XR1 lite](https://images.evga.com/articles/01505/XR1-lite.png)
The EVGA XR1 lite capture card allows you to capture every epic gameplay moment - Record at 1080p/60fps while you game at 4K/60fps. The new compact design and USB 3.0 are perfect for capturing gameplay or connect it to a DSLR camera for a high-quality webcam option.
![OBS](https://images.evga.com/articles/01505/obs.png)
Certified for OBS™
The EVGA XR1 lite is certified for OBS™. OBS™ is a free and open source software for video recording and live streaming. Download and start streaming quickly and easily.
XR1 lite capture device
Specification
- Interface: USB 3.0 Type-C
- Input & Output Interface: HDMI
- Video Input Resolution: 480p / 576p / 720p / 1080p / 2160p @60fps
- Video Passthrough Resolution: 480p / 576p / 720p / 1080p / 2160p @60fps
- Max. Capture Resolution: 1080p @60fps
- Video Format: RAW
- Dimensions: 100mm x 73mm x 15.6mm (L x W x H)
- Weight: 75g
Features
- 1080p @60fps Video Capture
- 4K @60fps Input / Passthrough
- Certified for OBS™
![XR1 lite](https://images.evga.com/articles/01505/capture-device.png)
