evga geforce ® RTX™ 2060 gaming cards
everything is new
Completely Redesigned From the Ground Up:
- First Ever Hydro Dynamic Bearing (HDB) VGA Fans Offer Lower Noise and Longer Lifespan
- New Fan Blades, Rotation Direction and Hub Designed for Quiet and Efficient Operation
- EVGA Precision X1 Software Gives You New Ways to Overclock
The EVGA GeForce RTX 2060 Graphics Cards are powered by the all-new NVIDIA Turing architecture to give you incredible new levels of gaming realism, speed, power efficiency, and immersion.
With the EVGA GeForce RTX 2060 Graphics Cards you get the best gaming experience with next generation graphics performance, ice cold cooling and advanced overclocking features with the all new EVGA Precision X1 software.
NVIDIA TURING
GeForce® RTX graphics cards are powered by the Turing GPU architecture and the all-new RTX platform. This gives you higher performance compared to previous-generation graphics cards and brings the power of real-time ray tracing and AI to games.
Real-time
ray
tracing
in games
Powerful
ai
enhanced
graphics
Graphics Reinvented
With the new NVIDIA Turing™ GPU architecture and the revolutionary RTX platform, RTX graphics cards bring together real-time ray tracing, artificial intelligence, and programmable shading. This is a whole new way to experience games.
Hydro Dynamic Bearing Fans
First HDB fan on an NVIDIA graphics card optimizes airflow, increases cooling performance, and reduces fan noise by 15%, compared to more commonly-used sleeve-bearing fans on graphics cards. The special upraised 'E' pattern on the enlarged fan allows a further reduction in noise level by 4%.
Next-Gen Overclocking
With a brand new layout, completely new codebase, new features and more, the new EVGA Precision X1 software is faster, easier and better than ever. www.evga.com/px1
Your choice
EVGA GeForce RTX 2060 graphics cards offer you more ways to keep your system cool than ever before. Offering a variety of fan choices, heatsink sizes, and cooling technologies, you can select the card that fits your system perfectly.
EVGA GeForce® RTX™ 2060 2 Slot Cards are longer, but allow for more airflow at slower speeds with two fans. Utilizing a smaller fan hub, these fans feature a longer blade to increase airflow while remaining quiet.
Need more horizontal space? EVGA GeForce® RTX™ 2060 2.75 Slot Cards give you more front-to-back space without sacrificing cooling performance or acoustic noise. To enhance the cooling using a single fan, these cards use a taller fan hub specifically designed for the thicker heatsink to apply more force while keeping a lower noise profile.
Part Number | Product | Boost Clock | Fans | Cooling Type | Cooler Size | Power Phases |
06G-P4-2167-KR | EVGA GeForce RTX 2060 XC Ultra | 1830 MHz | 2 | Dual HDB Fans | 2 Slot | 8 |
06G-P4-2163-KR | EVGA GeForce RTX 2060 XC Ultra Black | 1680 MHz | 2 | Dual HDB Fans | 2 Slot | 8 |
06G-P4-2067-KR | EVGA GeForce RTX 2060 SC Ultra | 1755 MHz | 2 | Dual HDB Fans | 2 Slot | 6 |
06G-P4-2065-KR | EVGA GeForce RTX 2060 SC Ultra Black | 1680 Mhz | 2 | Dual HDB Fans | 2 Slot | 6 |
06G-P4-2063-KR | EVGA GeForce RTX 2060 XC | 1755 MHz | 1 | Single HDB Fan | 2.75 Slots | 6 |
06G-P4-2061-KR | EVGA GeForce RTX 2060 XC Black | 1680 MHz | 1 | Single HDB Fan | 2.75 Slots | 6 |
06G-P4-2062-KR | EVGA GeForce RTX 2060 SC | 1710 MHz | 1 | Single HDB Fan | 2.75 Slots | 6 |
06G-P4-2060-KR | EVGA GeForce RTX 2060 | 1680 MHz | 1 | Single HDB Fan | 2.75 Slots | 6 |
- CUDA Cores: 1920
- Boost Clock: 1830 MHz
- Memory Detail: 6144 MB GDDR6
- Memory Bit Width: 192 Bit
- Memory Clock: 14000 MHz
- Memory Bandwidth: 336 GB/s
Key Features
- Real-Time Ray Tracing
- NVIDIA® GeForce Experience
- NVIDIA® Ansel
- NVIDIA® Highlights
- NVIDIA® G-SYNC™ Compatible
- Game Ready Drivers
- Microsoft® DirectX® 12 Ultimate, Vulkan, OpenGL 4.6
- Built for EVGA Precision X1
- HDCP 2.2
- NVIDIA® GPU Boost™
- Supports NVIDIA NVENC Turing Encoder
- CUDA Cores: 1920
- Boost Clock: 1680 MHz
Key Features
- NVIDIA® Ansel
- HDCP 2.2
- CUDA Cores: 1920
- Boost Clock: 1755 MHz
Key Features
- NVIDIA® Ansel
- HDCP 2.2
- CUDA Cores: 1920
Key Features
- NVIDIA® Ansel
- HDCP 2.2
- CUDA Cores: 1920
Key Features
- NVIDIA® Ansel
- HDCP 2.2
- CUDA Cores: 1920
Key Features
- NVIDIA® Ansel
- HDCP 2.2
- CUDA Cores: 1920
- Boost Clock: 1710 MHz
Key Features
- NVIDIA® Ansel
- HDCP 2.2
- CUDA Cores: 1920
Key Features
- NVIDIA® Ansel
- HDCP 2.2
