Unrivaled
Performance
Platinum efficiency or higher under typical loads and 100% Japanese capacitors ensure long-term reliability.
Semi-Modular Design
The EVGA PQ power supplies use a semi-modular design. With only the 24-pin power connector hard wired directly to the power supply, the PQ allows you to use only the cables you need and leave off cables you don't need. Even better, the EVGA PQ is compatible with a variety of EVGA's Individually Sleeved Cable Kits.
Single +12V Rail
A single +12V rail offers the best power output, rail stability and compatibility with the latest hardware. EVGA 1000 PQ can provide up to 83.3A on the +12V rail!
Active Clamp Circuit Design
Active Clamp SR+DD Circuit Layout. Full DC to DC Active Clamp circuit design improves efficiency.
NVIDIA SLI Ready
Run multiple NVIDIA graphics cards for the ultimate gaming experience. The EVGA PQ gives you the power you need to drive these demanding systems and achieve the best overclocks.
Semi-Modular
A semi-modular design allows some cables to be removed from the power supply for ease of installation and removal. You can leave off unnecessary cables to improve case airflow, eliminate unnecessary wires and - best of all - reduce cable clutter.
100% High Quality
Japanese Capacitors
Platinum Rated Efficiency
80 Plus certification ensures your power supply isn't wasting power and turning it into excess heat. Under typical loads these power supplies are Platinum efficiency or higher.
World Leading
World leading warranty and support for 10 Years.
On 1000, 850, 750 PQ ModelsFeatures
- 80 PLUS Platinum certified, with 92% (115VAC) / 94% (220VAC~240VAC) efficiency or higher under typical loads
- Semi-Modular Design to reduce clutter and improve airflow
- Active Clamp +DC to DC design for efficient operation
Specs
- OPP (Over Power Protection)
AC Input | 100 - 240 VAC, 15-8A, 50 - 60 Hz | ||||
83.3A | |||||
Output Power | 1000W @ +50C |
Features
Specs
AC Input | 100 - 240 VAC, 12-5A, 50 - 60 Hz | ||||
MAX Output | 24A | 24A | 70.8A | 0.5A | 3A |
849.6W | |||||
Output Power | 850W @ +50C |
Features
Specs
AC Input | 100 - 240 VAC, 10-5A, 50 - 60 Hz | ||||
MAX Output | 24A | 24A | 62.5A | 0.5A | 3A |
750W | |||||
Combined | 120W | 750W | 6W | 15W | |
Output Power | 750W @ +50C |
