![](https://images.evga.com/articles/custom/back_to_top_arrow.png)
![1070](https://images.evga.com/articles/01161/header/evga_gtx1070ti_header_title.png)
![1070](https://images.evga.com/articles/01161/header/evga_gtx1070ti_header.jpg)
Ultimate Gaming with
EVGA Precision XOC + OC Scanner X
Take on today's most challenging, graphics-intensive games without missing a beat. The EVGA GeForce GTX 1070 Ti delivers the incredible speed and power of NVIDIA Pascal - the most advanced gaming GPU architecture ever created. This is the ultimate gaming platform.
Take your EVGA GeForce GTX 1070 Ti to the next level with exclusive EVGA Precision XOC / EVGA OC Scanner X integration. With the click of one button, EVGA Precision XOC will detect, scan, and apply your optimal overclock!
![OC Scanner](https://images.evga.com/articles/01161/features/GTX1070Ti_Article_OC_Scanner.jpg)
![Start Scan Save](https://images.evga.com/articles/01161/features/evga_gtx1070ti_article_startscansave.png)
![Player Unknown's Battle Grounds Performance](https://images.evga.com/articles/01161/features/evga_gtx1070ti_performance.jpg)
GTX 1070 Ti Comparison Chart
EVGA GRAPHICS CARD | PART NO. | MAX POWER | LED | BIOS | COOLER | POWER TYPE | BACKPLATE |
EVGA GeForce GTX 1070 Ti FTW Ultra Silent | 08G-P4-6678-KR | 235W | Yes (WHITE) | 2 | ACX 3.0 | 10+2 | Yes |
EVGA GeForce GTX 1070 Ti FTW2 | 08G-P4-6775-KR | 235W | RGB | 2 | iCX | 10+2 | Yes |
EVGA GeForce GTX 1070 Ti SC HYBRID | 08G-P4-5678-KR | 217W | Yes (WHITE) | 1 | Hybrid | 5+1 | Yes |
EVGA GeForce GTX 1070 Ti SC Black Edition | 08G-P4-5671-KR | 217W | Yes (WHITE) | 1 | ACX 3.0 | 5+1 | No |
EVGA GeForce GTX 1070 Ti | 08G-P4-5670-KR | 217W | Yes (WHITE) | 1 | Blower | 5+1 | No |
Available with EVGA iCX Cooling
(Part Number 08G-P4-6775-KR)
![EVGA GeForce GTX 1070 With iCX](https://images.evga.com/articles/01161/features/evga_gtx1070ti_1070_icx.png)
![9 Thermal Sensors](https://images.evga.com/articles/01161/features/sensors-EN.jpg)
![Fan Control](https://images.evga.com/articles/01161/features/evga_icx_article_fan_control_EN.jpg)
![Efficiency](https://images.evga.com/articles/01161/features/evga_gtx1070ti_efficient_EN.jpg)
![Full Control](https://images.evga.com/articles/01161/features/evga_gtx1070ti_PXOC_EN.jpg)
![Interactive Cooling](https://images.evga.com/articles/01161/features/evga_gtx1070ti_interactive_EN.jpg)
![](https://images.evga.com/articles/01161/features/GTX1070Ti_Article_peace_EN.jpg)
Optimized airflow fin design
An optimized air flow design directs air through the fin holes, while half open fins maximize airflow to important components and L-shaped fins increase surface contact.
![](https://images.evga.com/articles/01161/features/fin.jpg)
Interlaced pin fin on Baseplate
![](https://images.evga.com/articles/01161/features/pin_fin.jpg)
Diecast form fitted baseplate and backplate
Backplate makes direct contact with all vital components and new baseplate design with integrated heatpipe significantly reduces component temperatures
![](https://images.evga.com/articles/01161/features/baseplate.jpg)
Play longer! Overclock Better!
![](https://images.evga.com/articles/01161/features/overclock.jpg)
Interaction with Other Devices*
![Red](https://images.evga.com/articles/01161/features/reda.jpg)
![Green](https://images.evga.com/articles/01161/features/greenb.jpg)
![Blue](https://images.evga.com/articles/01161/features/bluea.jpg)
![Red](https://images.evga.com/articles/01161/features/redb.jpg)
![Green](https://images.evga.com/articles/01161/features/greena.jpg)
![Blue](https://images.evga.com/articles/01161/features/blueb.jpg)
08G-P4-6678-KR
- CUDA Cores: 2432
- Base Clock: 1607+ MHz
- Boost Clock: 1683+ MHz
- SLI Support: 2-way
- Type: GDDR5
- Width: 256 Bit
- Clock: 8008 MHz
- Speed: 0.25 ns
- Bandwidth: 256.3 GB/s
Key Features
- EVGA ACX 3.0 Cooling
- Microsoft DirectX 12 API
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- NVIDIA GPU Boost 3.0
- OpenGL 4.6 Support
- PCI Express 3.0
- VR Ready
- Vulkan API
08G-P4-6775-KR
- CUDA Cores: 2432
- Type: GDDR5
- Width: 256 Bit
- Clock: 8008 MHz
- Speed: 0.25 ns
Key Features
- 10+2 Phase Power Design
- Adjustable RGB LED
- Asynchronous Fans
- EVGA Double BIOS
- EVGA iCX Technology
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- VR Ready
- Vulkan API
08G-P4-5678-KR
- CUDA Cores: 2432
- Type: GDDR5
- Width: 256 Bit
- Clock: 8008 MHz
- Speed: 0.25 ns
Key Features
- Built in White LEDs
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- PCI Express 3.0
- VR Ready
- Vulkan API
08G-P4-5671-KR
- CUDA Cores: 2432
- Type: GDDR5
- Width: 256 Bit
- Clock: 8008 MHz
- Speed: 0.25 ns
Key Features
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- PCI Express 3.0
- VR Ready
- Vulkan API
08G-P4-5670-KR
- CUDA Cores: 2432
- Type: GDDR5
- Width: 256 Bit
- Clock: 8008 MHz
- Speed: 0.25 ns
Key Features
- NVIDIA® Ansel
- NVIDIA G-SYNC
- NVIDIA GameStream
- PCI Express 3.0
- VR Ready
- Vulkan API
