Introducing the EVGA FX Series fans - a fan designed for enthusiasts. The EVGA FX Series fans provide efficient cooling, while remaining whisper-quiet. The curved housing and tapered blade design provides more consistent airflow while reducing turbulence - this creates more static pressure without increasing noise levels. The FX Series also features a Teflon Nano-Steel bearing, which gives the fan a longer and quieter life. The EVGA FX Series will give your system what it deserves - silence, longevity, and cooling under pressure.
High static pressure
The FX Series fans offer up to 2-3 times greater static pressure, compared to other leading competitors. High static pressure is essential for moving air through radiators, CPU heatsinks, and some fan grills on cases. Higher pressure, however, doesn't equal extra noise; enjoy the cooling performance without hearing it.
Quietest high performance/high static pressure fan in its class
The FX's unique housing uses a curved design to reduce turbulence caused by airflow reflected off surfaces, such as radiators or fan grills, resulting in better airflow, static pressure, and reduced noise.
Designed for chassis and radiator
The dual-threat of the FX Series fans means you don't have to make up your mind about purchasing an “airflow” or “static pressure” fan - the FX Series fans excel at both! These fans not only provide enough static pressure to power through any radiator, but also move large volumes of air to keep your case well-ventilated. Whatever your need, these fans can handle it!
15%+ More CFM compared to competitors
The tapered design improves airflow and gives the fan a unique look while spinning. More importantly, the design accelerates the fan's primary function - to move air, and lots of it!
Teflon Nano-Steel bearing with 80k hours MTBF backed by EVGA's 3 year warranty
Teflon Nano-Steel bearings ensure an exceptionally quiet experience, while averaging a long lifespan of 80,000 hours MTBF. Even better, these fans are backed by EVGA's 3 Year Warranty to get you back in the game if something does happen.
PWM-controlled
Take full control of your fan speed with the reliability and response provided by a PWM connector.
World-leading EVGA 3-Year Warranty ensures that these fans will keep your system cool for many years to come.
Specifications
- Fan Size: 140 x 140 x 25mm
- Fan Bearing: Teflon Nano-Steel
- Fan Speed: 600-2200RPM
- Fan Airflow: 113.50 CFM (MAX)
- Fan Static Pressure: 4.20 mmH20 (MAX)
- Fan Noise Level: 16.0 dB(A) (MIN) – 39.5 dB(A) (MAX)
- Warranty: 3-Year Limited Warranty
Key Features
- Designed for Chassis and Radiator: The FX fans were designed to excell at both high airflow and high static pressure. These fans perform equally well to the task, regardless of being installed in a chassis or on a radiator.
- High Static Pressure: The FX Series fans offer up to 2-3 times greater static pressure, compared to other competitors. This pressure is essential for cooling radiators and CPU heatsinks.
- PWM 4-Pin connector allows you to control the fan via PWM signal, ensuring that the fans spin exactly the way you want!
- Quietest High Performance / High Pressure Fan In Its Class: The FX's unique curved housing reduces turbulence caused by airflow reflected off surfaces, resulting in better airflow, static pressure and reduced noise.
- Tapered EVGA Fan Blade improves airflow and creates a unique look while spinning.
- Teflon Nano-Steel Bearings allow for quiet and long-lasting performance.
Specifications
- Fan Size: 120 x 120 x 25mm
- Fan Speed: 500-2400RPM
- Fan Airflow: 74.82 CFM (MAX)
- Fan Static Pressure: 4.04 mmH20 (MAX)
- Fan Noise Level: 16.0 dB(A) (MIN) – 39.9 dB(A) (MAX)
Key Features
